B&G Coilovers VS. Tein S-tech with Tockico or Koni
Old Nov 5, 2004
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Comfort wise, which is better? I heard B&G were one of the most comfortable coilovers out there but how does it compare to aftermarket shock/springs?
Obviously the coilovers are better for many other reasons but based purely on comfort and a smooth ride which is better?
Old Nov 5, 2004
dezod's Avatar
7thgen Power Maker
True coilovers are almost always gonna be better handling and ride than because the spring rates and dampening are matched unlike your spring & shock setup, unless you did serious suspension homework, which most don't do. Get coilovers, you will not be disappointed. PM me if you need hook ups...
Old Nov 5, 2004
ImPulse's Avatar
Get the coilovers... Way worth it, and you can adjust the height. I like my tein ss coilovers when i went to the shop they said they were "the nicest set-ups they have ever seen"
B&G is good aswell but, only if u want to be lowered to 3"'s
Dezod will take care of you
Old Nov 6, 2004
mykungfuisthebe's Avatar
mykungfuisthebe is an unknown quantity at this point
ive heard no good reports on s techs... nothing realy bad but they are too soft imo. custom spring rate springs (400lbs+ front 500lbs+ rear) or i hear H&R race are good and stiff, with konis this will produce about the same as fully adjustable coils,
so far the only problem i have heard of with any full coils is breakage, but most of the time its fixable
Tedverseti
Apr 23, 2020 01:45 PM
Cam Diaz
Sep 29, 2015 07:17 PM
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
