coilovers????
Old Oct 28, 2004
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
coilovers????
has anyone heard bout these http://www.vaos.homestead.com/COILOVERS.html
thanks
Old Oct 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Never heard of them but save for a couple of well-known brands (Ground Control, Skunk2) I would say steer clear of sleeved coilovers like these. Save your money for a full coilover set or a set of springs with good shocks OR Ground Controls with Konis, which seem to be a decent combination.
Old Oct 28, 2004
Mr.Modify's Avatar
yea never heard of them....if your getting sleeved go with GC's
Old Oct 28, 2004
shmik1's Avatar
their website is hosted w/ homestead..?
Old Oct 28, 2004
mradam85's Avatar
what does that mean?
Old Oct 29, 2004
InsaneK9's Avatar
InsaneK9 is an unknown quantity at this point
Link to GC
Link to GC
I'm debating whether or not to do my suspension myself or have a shop do it. What's the best way to find a good shop?
K9
Old Oct 29, 2004
mradam85's Avatar
do i really need coilovers? im going to school in wy, and it deffinetly snows here, but i would like to know how much trouble i will have in the winter time if i were to just go with lowering springs?
anyone have this situation?
Old Nov 1, 2004
mradam85's Avatar
hello? anyone?
Old Nov 1, 2004
matrix311's Avatar
matrix311 is on a distinguished road
dont get those, get something named brand, especially when it comes to suspension. It's the #1 thing you use the most on your car besides your engine. So treat it well and it'll treat you well.
Old Nov 1, 2004
TeLLy's Avatar
I rode around in winter slammed on H&R's. No problems really, and all the drivers behind me were grateful for the free snowplowing. This year though I've got full coilovers so I'm just gonna raise it up.
Think of it this way - either you spend $600+ for springs and shocks (nothin wrong with that) or $800 for coilovers, which are even better cause of the adjustability.
Old Nov 1, 2004
hondaciv01's Avatar
hondaciv01 is an unknown quantity at this point
don't buy sleeved coilovers unless you plan on going all out. ie redoing everything in the suspension. learned that one from experience.
Old Nov 2, 2004
mradam85's Avatar
i dont think im gonna get 'em but i was just wondering if anyone had 'em or not. Would i be safe in the winter with like a two inch drop in the snow? how much do H & R 's drop it? also would i need a camber kit?
Old Nov 2, 2004
shmik1's Avatar
its listed in the suspension FAQ they ALWAYS reccomend a camber kit, I have sportlines and no camber kit, my rear wheels look a bit off camber wise, it was aligned and im not seeing any irregular tire wear yet, once i have extra $ to spend im'a get camber kits.. 2" drop might be a bit much for snow.. my 1.5" drop still keeps me relatively high off the ground.. 2" might be ok tho, depending on how much snow u get and where u live in regards to plow route.. 2" should b fine tho i think.. not sure tho
Old Nov 2, 2004
Mr.Modify's Avatar
sucks for you....i been riding on GC's for a year. Nothings been replaced.
Old Nov 2, 2004
TeLLy's Avatar
No real need for a camber kit until WAY past 1.5" drop. H&R's drop 1.3 according to their site. Seriously though people freak out about tire wear due to camber WAY too much on this site. It's sad. Get it straight, you won't even NOTICE camber wear on your tires until past 2" drop or you peel out and powerslide every day on your way to work or school. I had H&R's on my sedan and when I took the summer rims off for winter, I couldn't even tell which tires were front (had no camber at the time) or rear (approx -2.5" camber). The real killer is toe settings. Make sure your toe is zeroed out, or you'll chew through your tires like mad. Get an alignment two weeks after you drop and you should be fine.
BTW for anyone considering H&R's (great springs) for 01+ Civics - do NOT install them on a sedan. Rear end sag will be horrible.
Old Nov 2, 2004
mradam85's Avatar
TELLY thanks alot man. very informative. i could care less bout tire wear. and btw your totaly right about people caring to much about camber wear. the only reason i asked about the camber kit was 'cause i didn't know if i would be loosing alot of traction or not, but it looks like you live in ontario and i would guess you get alot of snow there. so do you have any problems in the winter with your car being lowered? What type of suspension setup are you running now? What type of struts would you recomend with H&R's on an 2003 EX Coupe? thanks again for the info
Old Nov 2, 2004
TeLLy's Avatar
Well, was running only H&R's on stock (blown pretty quick) shock/struts and in the winter, save for the free snowplowing (the mayors of Mississauga, Toronto, and Hamilton owe me snowplow pay), the car was fine. Handled great on my winter rims and tires. I eventually got sick of the rear end sag and bounce from the blown struts so went over to Hayame full coilovers (version 2) this past spring. I like them a lot but frankly I wouldn't recommend them because everyone else except me seems to have problems with this particular model. Apparently the Hayame v1's are better.
As for recommendations, there's Tokico and Koni. I haven't had much experience with either brand on a 7thgen vic, but I thoroughly enjoyed the ride in my friend's 1.7EL on Neuspeed Sports (pretty close to H&R) and Koni Yellows. I don't think I've ever ridden in a 7thgen with Tokicos.
Old Nov 2, 2004
mradam85's Avatar
whats the best/cheapest place to buy spring & struts? and have anyone TEIN S-TECH Springs on their vic?
Old Nov 2, 2004
TeLLy's Avatar
Why not hit up one of our vendors? Dezod, Robear, Truehonda, Hondawerx, etc they're all good, all proven...
Old Nov 2, 2004
mradam85's Avatar
thanks so much for the info man! your the coolest dude ive found on this site! your awesome
Old Nov 2, 2004
TeLLy's Avatar
No I'm not. I'm just the one who has too much free time at work. Thanks though.
Old Nov 2, 2004
shmik1's Avatar
I prolly wasnt gonna get a camber kit unless I had wear that I KNEW was from bad camber..
Old Nov 2, 2004
mradam85's Avatar
i think i might just go with h&r's but not sure wich struts. do any sites sell like "pakage deals"?
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
