shocks for about a 2" drop
Old Oct 24, 2004
gotrice's Avatar
gotrice will become famous soon enough
im searching but cant find much. im looking for shocks on an 03 civic with a drop of about 2". some say that tokicos cant handle that low of a drop and some have said that koni's either but some say yes they will. which shocks would work best with that low of a drop. also, have you heard any problems consisting the modifications needed of any shocks for the 03?
Old Oct 24, 2004
xgimmick's Avatar
xgimmick will become famous soon enoughxgimmick will become famous soon enough
i thought tokicos were only for 01-02 and konis will work with 03s... i think you can modify the tokicos to fit with 03 though i think ?
Old Oct 24, 2004
jttegx's Avatar
OMNES AD UNUM
tokico's are not recommended for a 2" drop. 1.5-1.7 work best with tokico blues. and yes, for the 2003+ civic models, when installing tokico blues, you have to extend the knuckle bolt from 14mm to 16mm. honda decided to use larger bolts on the 03+ civics i guess. this goes for the fronts only that i know of. rears will slip right in as if it were an 01-02.
koni yellows would be a great choice of a shock for a 2" drop depending what springs go with it. they are pretty dam pricey tho so i guess thats why no one has them..
check out the shock/damper faq page.
Old Oct 24, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/forums/sh...d.php?t=171892
Old Oct 24, 2004
gotrice's Avatar
im using goldline but i read somewhere that the konis have to modified as well to fit the front?
Old Oct 24, 2004
robbclark1's Avatar
READ WHAT I JUST POSTED!!! It is stickied at the top of this forum!
Old Oct 24, 2004
gotrice's Avatar
1) Koni yellows - The front struts need to be modified for them to fit.
how do they need to be modified for them to fit?
Old Oct 24, 2004
robbclark1's Avatar
We have a DIY section...
Old Oct 24, 2004
gotrice's Avatar
ok thanks, have you heard any of any bad experiences with modifying them? any possible problems?
Old Oct 24, 2004
robbclark1's Avatar
search for koni in the suspension forum. Any time there is modding and not a direct swap you increase the chance for error. Also, the rear perch may fall out, but I think they fixed that. I would suggest konis just because of their reputation. If you are looking for a decent alternative, the D-spec tokicos would be a good choice.
Old Oct 24, 2004
gotrice's Avatar
alright coo ill check on those thanks
Old Oct 24, 2004
2K1Civic17"Gabe's Avatar
Since goldlines are supposedly 1.75, you should be ok, did you measure your drop? I would think .05 wouldnt matter too much in difference. I ordered tokico blues last tues, and am ordering goldlines this monday. Did they settle at about 2 inches? that would be nice to know.
Tedverseti
Apr 23, 2020 01:45 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
