Driving long distances while dropped?
Old Oct 15, 2004
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
Can any of you guys and gals see any problem with me dropping on goldlines while i have to drive out of state a lot?
They give a 1.5" drop rear and 1.75" front. I have 215/45/17 tires.
Any rubbing issues, exstensive wear i could face.
Thanks...
Old Oct 15, 2004
robbclark1's Avatar
Retired suspension supermod.
yeah, you will ruin your stock shocks
Rubbing issues and uneven wear would be determined by camber. You will have extensive wear on your tires because of the long drives, not the lowering.
Old Oct 15, 2004
Thanks robb... I am also going to get some tokico blues soon. Would this help the situation? I will probably get a camber kit also.
Old Oct 15, 2004
taz757's Avatar
I've driven from Virginia Beach, to Rockville, MD which is ~225 miles 3 different times in about the last month or so. Then I've driven all over MD to Baltimore to Hagerstown and whatnot. The Goldlines ride perfect, except for the blown shocks.
Plus I've driven out of town out west quite a bit with my car. Goldlines ride fine. 215/45 will be perfectly find. Don't sweat it.
Old Oct 15, 2004
dezod's Avatar
7thgen Power Maker
Well my 7thgen has been lowered atleast 1.5" or more for atleast 1.5 years. No crazy tire wear because camber is properly accounted for with camber adjustment kits. Remember your ride is always more stiff/bouncy when your lowered lots. The car has been to NYC, Philly, Atlantic City, Toronto.......All from 1-8.5 hour drives away. No probs here.
FYI: The car is lowered on KW Suspsensions V2 Full Inox SS Coilovers
Old Oct 15, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
2100 miles from my home to parents. Drive it once a year, and my car has been lowered the whole time.
Get a camber kit, have your alignment checked. Plus while it is on the rack, you can check the other things like ball joints, tire wear, etc.
If your car checks out (i.e. aligned with a kit), then the wear should be normal. I still have the stock shocks and the ride is not that bad unless they are repairing the highway. This year will be on Tokico D-Specs, so I will enjoy that.
Plus I am adding Sirius radio, cause the stations suck and maybe upgrading my amp.
Old Oct 15, 2004
hustlelikem0fo's Avatar
i drove from philly to atlantic city and back like 10 times this summer dropped like3 inches and on 19s........ you should be fine
Xuhme
21
Aug 7, 2023 03:40 PM
jackoncruzpr
May 24, 2015 12:24 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
klam
Nov 19, 2001 05:46 AM
