Need Answer Quick-please!!!!!
Old Oct 15, 2004
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I was installing my rsx-s 19mm sway bar, and while removing the endlink bolts, i didn't realize you are supposed to use an allen wrench in the end of the bolt. anyways, i just turned the 14mm bolt until the whole bolt and everything was turning! afterwards i saw your supposed to hold the bolt with an allen wrench and then use the wrench to get it off. Anyways, i inspected the rubber boot, it looks okay, do you think the endlinks will be okay? I pried on the pretty hard, and like I said, the hole was was just turning. Please help me....
Old Oct 15, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Should be OK if the boot is intact. Just make sure you use a lot of WD-40/Liquid Wrench to loosen up the bloody thing, then put the allen wrench on and use a 14mm wrench to get that sucker off.
Old Oct 15, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Its a ball joint. Its supposed to spin. Thats why you need the 5mm allen wrench, to hold it still.
Old Oct 15, 2004
tfnaaf's Avatar
BLDNPSI Mod
As long as you weren't using an air tool to try to spin the nut without holding the stud you should be ok. Like rob said it is designed to turn but if its turned excessively it can cause damage to the joint.
Old Oct 15, 2004
fuledya's Avatar
Super Member
Thanks guys, finally got it off, after I broke the aalen bolt off and it jammed inside the friggin hole. Everythings back on, and ill try the 19mm sway bar out tommorow.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Tyler93
Detailing
Oct 24, 2015 09:48 PM
Islesfan
Sep 29, 2015 03:42 AM
NROD315
Sep 23, 2015 03:46 PM
Jrosa
Sep 14, 2015 08:24 PM
