Coilovers
Old Sep 29, 2004
revern's Avatar
revern is an unknown quantity at this point
Coilovers
I was curious to know if people think its really worth getting coilovers if your not gunna replace the stock shocks and struts because i was looking into getting coilovers but i still want good ride quality so its not torcher to use as a daily driver. Let me know what you think
Old Sep 29, 2004
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
coilovers are very worth it. i have the Tein SS coilovers and i love em. very nice ride. and im picky. you get what you pay for.
Old Sep 29, 2004
Mr.Modify's Avatar
if your talking about sleeved coilovers i think it's worth it....the ride isn't all that bad then what some people make it.
Old Sep 29, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
If you only replace the springs and not the OE shocks, your ride quality will suffer. Maybe not today or next week, but eventually. Lowering the car with only springs will blow the shocks. IMO...Do it right the first time. Save for a good set of full coilovers.
Old Sep 29, 2004
revern's Avatar
The teins come with new shocks and stuts dont they? So i should definatly wait until i can get coilovers and shocks at the same time?
Old Sep 29, 2004
fuchs's Avatar
Yeah...Tein's are one of a few companies that make a good coilover set-up. If you are not dying to drop your car...I would wait.
Old Sep 29, 2004
revern's Avatar
So do you also suggest i get teins or are there better setups out there i should look at?
Old Sep 29, 2004
fuchs's Avatar
B&G, Tokico...there are a few more. Do a search for "full coilovers" and read away.
Old Sep 29, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
TEIN or B&G, B&G drops lower while TEIN has damper adjustability. What is important to you?
Old Sep 29, 2004
revern's Avatar
Id like a nice drop but i definatly want to be able to adjust them
Old Sep 30, 2004
RedDragon333's Avatar
Tein is a good one to go with, Hayame, B&G there a re a few others but those are some of the better full coil over systems for our car.
Old Sep 30, 2004
TurboDreamZ's Avatar
Super Member
TurboDreamZ is an unknown quantity at this point
id consider a full tein suspension .. best of the best.. may wana look into koni's with some coilover setups
Old Sep 30, 2004
revern's Avatar
Any particular vendors i should look into?
Old Sep 30, 2004
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
would 01-03 civic ex coupe coilovers fit onto a 2004 civic ex coupe?
Old Oct 1, 2004
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
Koni sports with Ground Control coil over is also a good set up beside Tein. To save you time & money, just replace the shocks. The OE shocks will wear out a lot faster using a coil over or any aftermarket lowering springs.
Correct me if I'm wrong but I believe the 2001-2003 Civic is using the 50mm OE struts & the 2004 & up is using the 55mm OE struts from the Acura RSX. I think that's the only difference. I'm not sure if there is anything else that's different though.
Old Oct 1, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
TssCivic, from what I gathered from this site, the 2002(later batches) and 2003 up uses the 55mm struts.
Old Oct 1, 2004
Mr.Modify's Avatar
yes sir
Old Oct 1, 2004
dezod's Avatar
7thgen Power Maker
I have KW Variant 2 Full Coilovers. 2 thumbs up. Lot of height adjustment and rebound all on a Stainless Steel coilover. Can't beat it.
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
