KW Rear Driver Side---Blown
Old Sep 25, 2004
jedo's Avatar
jedo is an unknown quantity at this point
My KW got blown after one year of use. I was checkin it this morning and I could see the oil poured out of the shock absober. I thought it would last long, but I was mistaken.
I will try to if I can use my warranty. To KW users, hows your KW? peace out.
Old Sep 25, 2004
opto_isolator's Avatar
Well....I can tell my front is a little bit more bouncy than before. I have a little over a year on them, and don't abuse them. My dampners are cranked as far as they will go. I don't notice any leaking, but I can tell they aren't as stiff as before. Good thing about them is the warranty....Let us know how it goes.
Old Sep 25, 2004
Ocelaris's Avatar
Ocelaris is an unknown quantity at this point
blah, we just talked, but I'll add my .02$ My front passenger's side is WOOSHING bAAAADDDD after I installed the KW upper bearing mounts... I gotta go check them out again see if anything is loose, but I'm worried...
Old Sep 25, 2004
Talked to whom? KW?
What is wooshing??
Hmmm....wonder if they are all like this....?
Old Sep 25, 2004
robbclark1's Avatar
Retired suspension supermod.
Ocelaris just talked to jedo and he just installed the upper mounts. That is what is causing the noise. IT is probably not tight or installed correctly. TAke some pics Bill.
Old Sep 26, 2004
Ocelaris's Avatar
Yeah, I am thinking something is loose... since when I first drove out of the garage, the damper screw was not tight.... pulled right back in, and tightened that down, made it sound 10x better... but still getting some wooshing, so I'm wondering if it's just that nut that has to be tighter... you can take my opinion with some salt, I've only had 1 coilover ever, and only installed it myself... so YMMV...
mohawkboom
67
Aug 25, 2015 12:28 AM
Billybob1963
May 31, 2015 07:37 PM
leon1
Apr 28, 2015 07:32 PM
ej8
Apr 13, 2015 06:36 PM
supercivic01
South
Nov 30, 2001 11:27 AM
