Clunking in rear w/ B&G's
Old Sep 20, 2004
beardedhippo's Avatar
beardedhippo is an unknown quantity at this point
I've just put a set of B&G coilovers w/ SPC's camber kit on my 2002 sedan. I'm still riding on stock rims. I have the coilovers set up so that the rear is just tucking. I'm getting this annoying clunking sound from both sides in the rear whenever I go over bumps at lower speeds. Anyone have any ideas what it could be? Thanks in advance.
Old Sep 20, 2004
pbfoot's Avatar
did you tighten all the bolts? i know its a silly question to ask, but when i installed my springs thats what i did. you might also need to check that youre not bottoming out, like if youre ride height is set too low.
but ill leave that to someone who has b&g's.
Old Sep 20, 2004
mndthegap1's Avatar
i dont know if its the same with b&g's or full coilovers BUT i have ground controls and koni yellows and i had the same problem in the front. the problem i had was there is a little plate that goes on the top, and it wasnt sitting correctly so it would make the noise when it hit bumps.....
maybe that might help
Old Sep 20, 2004
yeah, i've checked all the bolts. i am pretty low in the back right now so I think I may try raising it up a bit.
Old Sep 20, 2004
slicksivik's Avatar
yea my squeek like hell, i thought it was my body kit cuz when ever i when over just dips in the road it would squeek cuz of the tension i guess from the springs in the body. im to the tire in the back on 16's. i think its just the springs compressing i think, cuz mine are still quite new. i dont see a problem with it. its weird too cuz its only my back right too lol.
Old Sep 21, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
Check your tires and fender wells to see if they are rubbing. If you tucked it, theres a possibility that you went to low, and it could be just bottoming out. A raise in height like you said just might do the trick.
Old Sep 21, 2004
I wish they'd just start selling cars slammed as an option so you wouldnt have to deal with this kinda siht!
Old Sep 22, 2004
Al_ics's Avatar
Al_ics is an unknown quantity at this point
mine squeeks and clunks on the back right as well...
and its probably because its on the lowest setting
anyway, i tried raising the rears up yesterday and it wouldnt budge...anyone got any tips on how to adjust the rears??
Old Sep 23, 2004
duyaknow's Avatar
Dang, maybe try some wd40 to clean out any dirt that may cause your spring perch to freeze stuck like that.
Old Sep 23, 2004
K20me's Avatar
Clunking sounds in the rear? Does it sound like someone is in the back of your car crushing cans? If so, it could be your dust boots (I'm assuming you used your stock dust boots for your B&G's). I have Teins, and I had a clunking problem too in the rear. The coilovers were actually hitting the dustboots and that's how the sound occurred. I solved this by trimming the boots about 1/2" to 3/4". Maybe that's your solution. Good luck man.
Old Sep 23, 2004
Al_ics's Avatar
I tried wd40, and it still wouldnt move...
Also, when i try to move the perch i notice that the bottom bolt (in the pic) has some movement...is that a bad thing?
I stopped trying cuz i thought it might do some sort of damage
Old Sep 24, 2004
duyaknow's Avatar
That is a problem that you should look at. I remember reading something that your bushing or something in there can be damaged. It would be because you over torqued the nut. Some one warned me that you should not torque it down hard until you drop your car to the ground. Can you remember if you did that or not? Check to see if there is damage in that area.
Old Sep 24, 2004
Al_ics's Avatar
so that bottom part should not have any movement watsoever??
I had these installed at a local and reputable performance shop...
Old Sep 24, 2004
i got under my car last night and noticed that one of the rear dust boots was torn......i thought that they might be the reason for the noise so I cut the one torn one out........no luck, it was still making noise.........my plan is to try and get some new boots from b&g for the rear but this time cut them in half...at that point i also plan to cut the bump stops in half.......i have a feeling that they are they reason for the noise because nothing else under the car appears to be loose........does anyone have any other input on this
Old Sep 26, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Have you checked the inlets for the lower bolt? If the inlet ripped, you might need a new strut and make sure that bolt is properly installed. (Screw in with the car up, tighten once the car is on the ground.)
