Keeping coilovers clean?
Old Sep 11, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
How do you guys keep your coilovers clean?
Old Sep 11, 2004
robbclark1's Avatar
Retired suspension supermod.
Uh a little simple green and water if they are greasy. Other time, just a wipe with the sponge.
Old Sep 11, 2004
streetglower's Avatar
why does it matter if they are clean? They are just going to get dirty from all the road grime and what not. And no one really sees them.
Old Sep 11, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Because the threading will corrode.
With a toothbrush and a lot of water. Then a shot of WD40 when they dry.
Old Sep 11, 2004
Just spray them with water when you wash your car.
Old Sep 12, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
idk my threads stay clean, i dotn have dust boots but my shock part stays clean...i just drive really fast in rain.. and if needed i rub em down when im detailing my wheels..
Old Sep 12, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
I heard WD-40 is bad for suspension?
Old Sep 12, 2004
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
Dont know if its bad for suspension in general BUT it is not very friendly to rubber parts.
Old Sep 13, 2004
robbclark1's Avatar
WD-40, besides being a lubricant, is a general cleaner. It is bad for rubber, but other than that you can use it to clean hard surfaces like, metal and most hard plastics.
Old Sep 13, 2004
Jap-Euro Fusion
You heard wrong.
WD40 is made for metal, thus it can't be bad for spraying metal threads.
Old Sep 13, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
I just use my pressure washer and hose down the threads, before winter you should clean the threads with a medium stiff brush. Lube the threads, and height adjustment collars with some antiseize.
Once a week or once every two weeks, during winter, while you wash your car in a wash bay just give the threaded area a quick rinse.
Old Sep 13, 2004
dvsdara's Avatar
dvsdara is an unknown quantity at this point
What exactly is this "antiseize"? Isn't WD-40 good enough or is there another product we should use instead?
Old Sep 13, 2004
MrWong's Avatar
Bushido
Antiseize prevents scews, nuts, bolts from being "seized". Seize is another word for stuck or a b i t c h to take off. The best example is when you are taking apart your suspension and you cannot take that bolt off unless you have air tools.
WD-40 is good, but not good enough mainly because it wears off too fast.
Rinsing them off once a week or every two weeks in conjunction with antiseize will help keep the coilover threads in top condition.
Old Sep 13, 2004
dvsdara's Avatar
Cool. Thanks MrWong. Thats good to know seeing that Fall is just about here and Winter is right around the corner too. I'll raise it up in before winter hits and spray some of that antiseize on it too.
Old Sep 13, 2004
ZdS03Civic's Avatar
You heard wrong.
Why does everyone suggest Lithium grease over WD-40 then?
Old Sep 13, 2004
robbclark1's Avatar
It doesn't make a difference. Silicone, lithium, wd40. Whatever, they are all lubricants, but with the greases, you can't just wash them off like you can WD40. They stay on and usually collect more dirt than anything.
Old Oct 2, 2004
dtexan's Avatar
dtexan is an unknown quantity at this point
Will the WD-40 dry out your seals any?
Old Oct 2, 2004
robbclark1's Avatar
If they are rubber yes.
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
jferristx
Jul 8, 2015 10:09 PM
92hatchbackcx
Jul 7, 2015 08:23 AM
