SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
Old Nov 16, 2004
  #31
robbclark1's Avatar
Retired suspension supermod.
Any of the shocks would be fine, it just depends on how you want to tune them and how low you want to go. When you consider those two things, pick up the set that you think best suits your needs. Not many people have the AGX or the DSpecs. Konis and the Tokico blues are the ones of choice right now. So it is hard to get you opinions on them. Maybe try trolling around EPhatch.com or clubrsx.com and see if they have anyone that has bought them.
Old Nov 16, 2004
  #32
prccivic's Avatar
well, my brother has the AGX's on his 6th gen civic right now and i really like the ride that they offer...so i was just trying to figure out if the D-specs are really worth the extra cash since it sounds like they are gonna be about 500-600 bucks
Old Nov 25, 2004
  #33
lilravingmatt's Avatar
lilravingmatt has a little shameless behaviour in the past
Unhappy
will tokicos blue work fine with stock springs... or is there a spring that you guys can recommend me 2 get with?... i dont want a lower car, i just want ride quality, less bumbyness... i used 2 have a lowered car... raised back up with OEM parts now its so bumby as hell worst then lowered... plz help THX
btw trying 2 save as money as i can... i dont plan 2 race... dont need performance... just want ride quality...
Old Dec 1, 2004
  #34
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
i want to get the tokico d-specs. they come with lowering springs and the shocks so is that like tein basic coilovers just not as good as them. and if they come with lowering springs i won't need anything else to add to it because i'll have the full kit right??
Old Dec 1, 2004
  #35
prccivic's Avatar
just camber kits after that
Old Dec 3, 2004
  #36
Chris3k2's Avatar
does anybody know how low a drop the d-specs allow??
Old Dec 9, 2004
  #37
CloudKICKA's Avatar
CloudKICKA is an unknown quantity at this point
I have an 03 LX and was hoping to get the tokico blues, this is the first I've heard of them not fitting on my model, is there any updates on their availability for the 03 yet, cuz drilling a hole and chancing it on the road doesn't sound too kosher for me??>....
Old Dec 12, 2004
  #38
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
rumors has it that the skunk2 coilovers arent compatiable with aftermarket shocks. i've talked to a buddy on the forums here and his kyb gr-2's doesnt give him a good fitment on his sedan thats dropped on skunk2 coilovers.
another member here also has had problems with his skunk2 coilovers and tokico blues. she or he posted a thread so look out for that one.
conclusion: if your lowering with skunk2 coilovers (not the springs), be caution of which aftermarket shocks/struts you invest into.
Old Dec 21, 2004
  #39
SaiyanMatador's Avatar
SaiyanMatador is an unknown quantity at this point
Let me tell u an embarrassing story real quick. I have to get it off my chest, I wrecked my 01 into a curb in phoenix Arizona, where im at. While Driving too fast (and for the people who know the area) up through the Pointe golf club drive, around the area of 7th st and thunderbird. well going past 16th st on the Pointe (which is 35 mph and single lane traffic flo) where I shoulda turned, because I was following some white Mazda 6, four cylinder, I let my racing mode set in and take control of my driving instead of the correct way of driving, SAFELY, LET ME REPEAT SAFELY!!!
instead of turning like I should a have, I kept on going, faster, and hit a turn that was a long 30mph that I had taken plenty of times, but it had just rained that day, and I hadn’t realized it when I was going, thinking I could take it that fast, for I had plenty of times taken the turn at such speed as I was going .
I believe when I entered the turn I was roughly around 78 to 84mph, in between there I'm sure, hit 4th gear and was roughly 4500 47rpm or so, have my lunar series on my driver side dash, its damn accurate, and autometer prolly will always be. therefore I had such a change in vehicles power band to possibly cause "the wheels" to break loose (even though passenger side driven, odd for Honda left hand driven!! driver side much more affective for weight on tranny) and send me right into the ooohhhh 7 to 8 inch curb. mind u my speed reduced from that of above to roughly 42 or so mph for the activity I triiiieddd to perform in order to gain control (i.e. turned the steering wheel back and forth, and tap tap gas and brake considerably, yet moderately. damn, fockin damnnnn
Damage: DRIVER SIDE CONTROL ARM, SNAPPED AT REAR INSIDE ARM, 3/4 ID SAY. Yet thanks to gray name GRey's end links the steering stabilizer held strong and snapped just the arm. replaced arm, Honda oe spec, 53 dollas yi yiii yeaaa
Damage B: alignment nearly aaaawaaalllled.. But thank god salvageable. Wonder how the new tokico blues I had I, did from the accident.
Damage C: Driver side spindle bent completely. I had figured that the control arm was massively ninja'ed, because i've had a snapped arm before for lettin drunk friend drive.... hit curb no drive satinsaiyan no more friend. I figured replace it, get it aligned it should be good.
Conclusion. My apologies for the length yet I hope all shall learn from this marthfocker list of vocab.
From the duration I Took the car to alignment shop, network alignment, driving car felt like shatttt, yes I said shattt. Steering mucho goofy, as if tires pointed out, or that’s what I tried to conclude while driving.
I then assumed it was the way I hit the curb. Slammmed hard at the speed with my wheels turned away from the curb, completely, I know, bad!,
waited to get aligned, bout five hrs, sucked, spent ma day there, garldarnit. just to have them tell me that something else was bent and or damaged. possible the two control arms shot, or shocks damaged or sway bars bent, they's dun know, theys idiots, I didn’t think it was much bent, maybe camber adjustment, and alignment, well. Yeah spindle bent much; with the new tokico blues I got connected. Alignment monkeys didn’t know wat was wrong, so I made a phn call, took it to Ceruttis Automotive, they diagnosed and explained what I aaaaaawaaalllllledd up.
control arm, I replaced, spindle cerutti replaced, new stock stealie with labor, alignment, new bearings on driver side, greased of course, id say whole nine yards job. 462.14. yall think good if so pm me for more info on this custom/certified repair, shop, ceruttis automotive, anyways, that was roughly end of august, and my car now with repairs intact and stock steelies with stock hubs, lolll. And the Tokico blues holdin strong with Neuspeed sports, 1.75 frnt, 1.5, rear. Ride decent but the car does not ride the same since the accident, plus THE WORST OF ALL, I HAD MY RIMS, 17" SPEEDY OCTUPUSES. APPLICATION OF ADR 8 SPOKE WITH DIPED CENTER RIM STYLE, CHECK MY PROFILE FOR PICS; I CAN TAKE AFTER PICS AS WELL,
POINT, SHOCKS HELD UP THROUGH ACCIDENT ALTHOUGH I BELIEVE WITH 12000 MILES ON EM. Damnit good morning
Old Dec 22, 2004
  #40
doinkracer's Avatar
doinkracer is an unknown quantity at this point
i know this sounds silly, but every website i go to, i cannot find a specific part number or app for civics 01 and above...does anybody have a website where they specify the the tokico shocks part number for 01 civics and above? thanks
Old Dec 23, 2004
  #41
robbclark1's Avatar
Straight fron Tokico's website. When in doubt go to the manufacturer's website or call them on the phone.
HONDA CIVIC 01-02 (exc. SI)
HP (in stock)
HB3204/3205 Front
HU3741 Rear
D-Spec Adjustable (in stock)
DSP-5
However, most places don't stock them with the manufacturer's part number.
Old Dec 25, 2004
  #42
flowerpowerlove's Avatar
just breathe...
flowerpowerlove is an unknown quantity at this point
do you guys think that the konis would go well with some neuspeed race springs? i like the drop of the springs, 2.25 fr, 2 back. looking to get a shock upgrade for autox ing...
Old Dec 26, 2004
  #43
robbclark1's Avatar
Konis are a great choice for autox.
Old Dec 26, 2004
  #44
dvsdara's Avatar
dvsdara is an unknown quantity at this point
All shocks, except for konis, are made for a 2001-2002, so the mount bolts are 14mm not 16mm like in the 2003+. Either you will have to drill them out or hope that the company makes a set for you guys. The can be put on your 2003+ but you run the risk of the mount bolts coming loose and the shock changing camber.
Quick question. How can the mount bolts become loose the shock changing camber? I have an 03 with B+G coilovers and the bolt holes drilled to fit the 16mm bolt. I haven't experienced anything but was just curious as to how something like you've mentioned might happen?
Old Dec 26, 2004
  #45
03CivicNyte's Avatar
03CivicNyte is an unknown quantity at this point
Thanks..
Old Dec 26, 2004
  #46
Boilermaker1's Avatar
Jap-Euro Fusion
He's talking about people using the 14mm crashbolts so they fit the shocks, while the holes in the knuckle are still 16mm. It leaves slop in it, the first pothole you hit, they're gonna move.
Simply out of my own curiosity, has anyone thought about making an insert for the 16mm knuckles that makes it a 14mm hole? Just a metal bushing? Kinda seems like it would have been the worlds easiest solution to this problem.
Old Dec 27, 2004
  #47
ojay's Avatar
ojay is on a distinguished road
this would be a more efficient solution than drilling. never thought of it that way... you're a genius boilermaker.
Old Dec 27, 2004
  #48
robbclark1's Avatar
I think the new KYBs or Tokico's are coming with them if they are ordering them for a 03+. There is a metal piece that fits in there to prevent sliding.
Old Dec 27, 2004
  #49
dvsdara's Avatar
I'm glad you mentioned this. I never thought about the size of my camber bolt. I ordered it and it sayed 01-up. Then this morning, I was looking at the SPC site and saw that they had different sizes. Then I realized, when my friend installed my B+G, he said he only had to drill the bottom bolt holes. So I just ordered new front camber bolts for 2003-up 16mm from ptuning.
Old Dec 27, 2004
  #50
dvsdara's Avatar
I just ordered the KYB's for my 03 from www.tirerack.com. If you select vehicle and put in 2003 Civic, the KYB won't even show up for a result of choices. I'm just gonna drill the bolt holes to fit the 16mm. I know there hasn't been any detailed reviews on this yet but I will def. follow up on them with full details. I know there's still lots of questions to be answered about the AGX's.
Old Dec 27, 2004
  #51
Jrfish007's Avatar
What's a good shock for the stock springs? Yes stock springs... I live in ohio and we just got about a foot of snow in one day, my car is already at snow plow stance adn my drive way is 600feet up hill, I need snow tires just to make it up it. SO lowering the car is a bad option. I was just wondering if anyone had put new struts on while retaining the OEM springs, or should I say ride hieght, I'm looking into geating a custom sett of springs made, stiffer but the same ride hieght.
Old Dec 27, 2004
  #52
dvsdara's Avatar
I think Eibach has springs that might suit your needs. I think they have a set that lowers it like 0.3in or something like that. Its close to stock height with a stiffer rate. I'm not too sure so don't take my word for it.
Old Dec 27, 2004
  #53
robbclark1's Avatar
Yes, aftermarket shocks with stock springs are completely fine. I would stick with the tokico blues if you aren't racing. You don't need the dampening adjustability. The KYB GR-2s would be a good second choice.
Old Dec 28, 2004
  #54
jttegx's Avatar
OMNES AD UNUM
has any companies made any shocks/struts specifically for the 2003+ civics?
Old Jan 9, 2005
  #55
Cocky's Avatar
Cocky guys kick ass!
which is best for a slammed car? i duno my exact drop.. but it's looooow! lol. i have Hayame V2's..
Old Jan 9, 2005
  #56
robbclark1's Avatar
No, not that I know of. Why would they? When they figure out the difference and people want them anyway, then people will figure out a way to make them fit. I heard either KYB or Tokico was going to but I don't know if that happened. Konis are for all years, you just have to measure the shock body size.
Cocky, what question are you asking?
Old Jan 16, 2005
  #57
Cocky's Avatar
Are Eibach Sportlines good with the Koni's? As far as comfort.. and will the Sportlines hold up well with the Koni's?
Old Jan 17, 2005
  #58
robbclark1's Avatar
Sure, Koni's should hold up to most things. If you are worried about it and want to go lower you can ask koni to make shortened shocks for you.
Old Jan 18, 2005
  #59
Profoxcg's Avatar
Profoxcg is an unknown quantity at this point
can somoene plase mark on a picture where to measure from and to?
thanks I need to buy konis of the front of my civic
Old Jan 18, 2005
  #60
robbclark1's Avatar
http://www.7thgencivic.com/forums/sh...t=koni+install
http://www.hondatuningmagazine.com/t...ht_suspension/
