Car seems to wander after bumps-please help
Old Aug 31, 2004
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I've searched, can't figure out why its like i gotta drive with 2 hands, just to keep the car in my lane - is this cause I have stiffer springs? Hayame V2 BTW, oh and save the "shoulda bought Teins" i don't need to hear it. Is this normal with all aftermarket full replacement suspensions? Anyone else have this problem?
Old Aug 31, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
aligment?
Old Aug 31, 2004
fuledya's Avatar
Super Member
yea, got an alignment, and camber kit, everythings good. 0 camber and toe in the front, i forget the rear.
Old Aug 31, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
It sounds like bump steer, common when your toe is out.
Old Aug 31, 2004
fuledya's Avatar
Super Member
camber readings:
left caster = 1.9
right caster = 1.7
0 camber both fronts
0 toe both fronts
rear left camber -0.2
rear right camber -1.3
0.10 toe both rears.
thrust angle = 0.0
I don't think the toes out, been on a lot of long trips, tire wear seems fine
The car feels like it did the first time I lowered it, before and after I got it aligned.
Now Im confused.....
Old Aug 31, 2004
streetglower's Avatar
Talk to matrix311, he is having the same problem and figured out it was because of the hayames. here read this thread and his second post
http://www.7thgencivic.com/forums/sh...d.php?t=171258
the srtut inside the housing wiggles too much and causes the toe to go out each time you hit a bump and it is causing your alignment to *** up.
Kalligarri is also having the same problems
http://www.7thgencivic.com/forums/sh...d.php?t=171156
Old Aug 31, 2004
fuledya's Avatar
Super Member
Yea, I read his post earlier, My problem is different. When I hit bumps, even little ones, the car likes to wander, and the steering feels real "light", and i am always compensating myself, back and forth with the wheel to keep it straight. It acts like the caster is off, but it's non adjustable on our civics......
Old Aug 31, 2004
talk to kalligarri, he is having the same problem with the car wondering.
Maybe boilermaker or zzyzx, or tnaff can explain how this works. They are the suspension experts.
Old Sep 1, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
tnaff.. zzyzx.. hurry ur *** up im waitin for an explanation lol
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
