Dropped too much & hitting exhaust (w. pics)
Old Aug 31, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
Question Dropped too much & hitting exhaust (w. pics)
Whats up everyone.
I just installed my B+g's a while ago, and then dropped my car pretty much to as low as i can go before rubbin my fat 215 45 17's. Now the problem i have is the exhaust hitting the control arm. Ive brought it to a couple of places and the people are idiots, and dont understand that i just want a section cut out of my over axle pipe, and a new piece welded in that bends higher. I know alot of people on the site are dropped probably lower than me, and have exhaust's, so what did you guys do? Is there another over axle muffler i can get that has a larger bend to clear the arm? Any remedies i can do by myself without having to have a shop do it? Thanks.
Pics
Old Aug 31, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Your not Dr. Smooth anymore heheehe
Old Aug 31, 2004
streetglower's Avatar
everything looks fine to me in your pics. It looks like the exhaust pipe is clearing the control arm fine. Are you only having the problem when you go over bumps?
Well I say go to a better muffler shop then the one you went to. Any shop should just cut the pipe out from the muffler to before the control arm and then weld another one in place.
Old Aug 31, 2004
^yah its fine untill i hit a bump. Its clanks and i can see marks on the pipe where the arm is hitting. Yah i know, but i dont want to get charged alot. Like its not a big job to do, but alot of places make is seem that way cuz it requires "custom work". Rediculous.
Old Aug 31, 2004
Well I had the same problem with mine, it only hit when I went over bumps. All it needs is more support. My shop welded something from my muffler to the top of the frame, and now the exhaust doesnt move at all. See if a shop can do that for you. No, it shouldnt cost much to have another piece put in, but try my thing first, they should have a way to make the piping stiffer so it doesnt move around.
Old Aug 31, 2004
^hmm that sounds like an idea. SO its the actual exhaust moving downwards, or is it the arm moving from impact of the bump. I though it was the arm moving up and down from impact rather than the exhaust. I could try that tho forshure. Shitty thing is if they weld something to my frame do u think it would rust in the winter? (snow)
edit: got any pics of the reinforcement?
Old Aug 31, 2004
no it is the exhaust moving around. everytime you hit a bump, it moves and hits the arm. All it needs is more support. I dont think it would rust, mine hasnt. It looks kinda odd if you get under the car and look at the piece welded from the muffler to the frame, but you cant tell otherwise, and it works great.
Old Aug 31, 2004
^sweet thanks! Ill keep it in mind. Any other ides from anyone else?
Old Aug 31, 2004
VTECTypeR's Avatar
Most muffler places should charge about 20-30 bucks to fix that problem. My friend had the same problem on his car it would always hit the control arm on the bumps. Its a simple fix. Just look at the yellow pages and call all the muffler places around your area
Old Aug 31, 2004
danscreations's Avatar
Tuckin' 19's
danscreations is an unknown quantity at this point
It looks like the bend needs to be steeper. That or when you get pissed do like me and get a custom one made and it will never hit, never make noise, never rattle, etc.
Old Aug 31, 2004
yea like everyone else said, you can get a deeper bend, but it will still do it again. Next time it would hit the top of the car. all it needs is more support because you look to have custom piping and usually custom piping doesnt have the same support as a catback or OEM exhaust. Unless the muffler shop does a good job and gives the same support to the custom piping.
Old Aug 31, 2004
^yah i guess soo...i jsut hate all the shops around here...the people are all clowns. I wish i knew how to weld, and i could do it myself!
dan: i love those control arms. Where did you get them? They look amazing! Good job!
Old Aug 31, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
i like those too...=)
Old Aug 31, 2004
they look like SPC Lower control arms.
Old Sep 1, 2004
^mmmm....id love to get silver ones....would look so slick behind my type b
Old Sep 1, 2004
how much are they?
Old Sep 1, 2004
HondaLuver's Avatar
Its a celebration bitches!
you don't have a sway bar
Old Sep 1, 2004
D5cIvIc's Avatar
what does "you don't have a sway bar" have to do with his exhuast hitting his control arm??
Old Sep 2, 2004
^^hahah took the words right out of my mouth!
so anyone else having this problem. It must be common for people who are dropped alot.
Old Sep 2, 2004
Well it has nothing to do with being dropped. the only problem you will run into then is the exhaust scraping on the ground if you are too low. Like I said your 2 options are to add support to the exhaust, or get a new pipe welded in there that is bent more.
Let me ask you this, can you move your muffler back and forth if you push on it, or does it not really move at all? Like doesn your whole exhaust move around when pushing on the muffler?
TheRiddicles
Sep 21, 2015 03:34 PM
TheRiddicles
Sep 21, 2015 01:28 AM
tuvok
Aug 28, 2015 10:04 AM
Matrix
Feb 11, 2002 08:20 AM
