Why Tein S techs make noise?
Old Aug 26, 2004
spyder2333's Avatar
EM2/DC5/LS1
spyder2333 is an unknown quantity at this point
I have a 2002 ex and i have the tein s tech springs, does anyone know why if im not moving and turn my wheel or if im making a u-turn my when i turn my wheel the spring makes like some sort of cracking noise?
Old Aug 26, 2004
kalipnoi's Avatar
kalipnoi can only hope to improve
sob....mine does that too. i don't know why but if you have your friend turn the wheel and you crouch down and look at the spring it hella jumps and ****. i only have my front suspension on right now cuz honda tightened the bolts to much in the rear. i'm thinking its because the bolts are too tight making the spring too compressed, but that just a guess. i don't have the tools to try and fix it myself. pm me if you find out what the problem is
Old Aug 26, 2004
spyder2333's Avatar
EM2/DC5/LS1
yea im dying to find out what its coming from...if i do ill let u know
Old Aug 26, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Sounds like spring is binding. There was a thread somewhere in this forum about indexing - have you checked it out?
Old Aug 26, 2004
spyder2333's Avatar
EM2/DC5/LS1
no where is that im new to this forum....thanks for help
Old Aug 26, 2004
beastiek2's Avatar
This cost me 1500 points
beastiek2 is an unknown quantity at this point
Dust cover?
Old Aug 26, 2004
Cipher's Avatar
Cipher is an unknown quantity at this point
i had the same problem, i bought tein ss coilovers and there was an annoying cranking sound. the sound only comes from one spring, usually the front right. you have to take the springs off and clean them and grease them up really well. the noise comes because there is too much loose dirt in the way and it causes thespring to behave incorrectly. I had to take my car to a local shop cuz i didn't want to take off my coilovers, but they saidit is due to the spring. the cleaned it off and greased up very well. now i take turns easily, without having people looking at my car and wondering what that awful cranking sound is.
Old Aug 26, 2004
SilverChick2k1's Avatar
Girl Mechanic; Boy Beater
SilverChick2k1 will become famous soon enoughSilverChick2k1 will become famous soon enough
What type of grease do you put and where do you put it at?
Old Aug 26, 2004
kalipnoi's Avatar
damn, now i have to take them off again. when it first started i thought it was something like that so i sprayed a bunch of wd-40 on them but i guess the trick is fully cleaning them while they're off.
Old Aug 26, 2004
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
Yea, same problem. I dont think its the tein springs though, i have Neuspeed sports. I spoke to my buddys cuz who is a honda tech and he told me the springs will eventually settle into place, and he said to re-tighten all the bolts that hold the shock assembly after they settle into place, because you may get another half turn or so.
Old Aug 27, 2004
spyder2333's Avatar
EM2/DC5/LS1
i put my spring on about 2 months ago as soon as i put them on they made the sound and to this day they still do
Old Aug 30, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
The S-techs on my girlfriends car makes a slight ticking at sharp turns or dry steer. I can't feel anything on the upper strut mounts when the wheels are turning. The springs stay in place the whole time and I did index them proplery. Any ideas about this one?? PS- I put them in my sedan and they make absolutely no noise.
Old Aug 31, 2004
z00mX's Avatar
z00mX is an unknown quantity at this point
a friend of mine had the same problem with the 2 front ones. and i took him to a local shop that i know and the mechanic said it was not aligning the springs and struts right. im putting mine on this sat. so i will pay very close attention to it to see what i can discover to help you guys.
Old Aug 31, 2004
BIG's Avatar
BIG
make sure that the arrows are lined up on top of the assembly
Old Sep 1, 2004
spyder2333's Avatar
EM2/DC5/LS1
Thanks kid....
Old Sep 2, 2004
z00mX's Avatar
i won't be getting my springs until tuesday... until than i have to wait...
Old Sep 3, 2004
HShadow's Avatar
I got my Tein SS coilovers on rigt now and I have that same problem too. Cipher is right, just put a couple of layers of grease and your problems will go away. I did that and still have the superior handling of the product intact.
reqy
Jun 1, 2015 07:05 AM
elitezdc5
May 26, 2015 05:46 PM
dosmastr
May 5, 2015 12:19 PM
SSMatey
Apr 13, 2015 06:09 PM
