Lowering question
Old Aug 8, 2004
MegaHurtz's Avatar
Lowering question
I just put some new rims on my car, now obviously the next step is to lower it.
I have noticed that with my fron wheels at least, the clearance between the top of my tire and the bottom cup thing that the springs sits in is pretty tight.
If I was to lower my car, would this clearance change or stay the same?
What about the back, are there any clearance concerns there, or any other ones on the front as well for that matter?
Old Aug 8, 2004
Mr.Modify's Avatar
SEARCH YOU NOOB!!!!!
hahahahahahahaa.....you'll be fine with any drop man as far as the clearance your talking.....im ****ing slammed on coilovers and have no issues what so ever!
Old Aug 8, 2004
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
The distance between the bottom spring 'cup' and the tire should remain the same. It will only change if you get taller tires. This is not the spot that will do the lowering. It is from the bottom of the 'cup' to the top part of the suspension mounting point that gets shorter, because of the shorter spring.
Old Aug 8, 2004
MegaHurtz's Avatar
Awesome, thanks
Out of curiosity, what is below the spring? the strut?
P.S. Akia is gay
Old Aug 8, 2004
Mr.Modify's Avatar
Originally Posted by MegaHurtz
Awesome, thanks
P.S. Akia is gay
P.S.S. STFU
Old Aug 8, 2004
robbclark1's Avatar
Retired suspension supermod.
Yes that is the strut which holds the shock. Read the FAQ for more suspension info.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
cukaracha
Jul 23, 2015 08:50 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
NoobyKid
Jul 13, 2015 07:53 AM
