Coilover torque specs?
Old Jul 26, 2004
7GRev's Avatar
7GRev is an unknown quantity at this point
Hey all, im going to install my hayame coilovers tomorrow and was wondering about the torque specs for all the bolts im going to be removing?
as well as the rear strut bolt torque specs... any help would be greatly appreciated
Old Jul 26, 2004
robbclark1's Avatar
Retired suspension supermod.
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
Old Jul 26, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Damn beat me to it.
Old Jul 26, 2004
7GRev's Avatar
Thanks so much
Old Oct 19, 2004
fuya_inc's Avatar
fuya_inc is an unknown quantity at this point
Thanks
Thanks for the specs!!!
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
