Squeaking noise
Old Jul 25, 2004
sffree's Avatar
sffree is an unknown quantity at this point
Squeaking noise
Yup.. another week...another squeaking noise thread. With regard to coil bind.. if the springs dead coils are rubbing.. does this cause a squeaking noise? I've had squeaking noise issues before... Once when I had an ingalls rear camber kit.. when I removed it and replaced it with Spc.. no more noise... then I had noise because of the pre-fix rear koni yellow shock.. remember how the bushing didn't fit right.. well they sent me replacements and now no noise... But now a new squeak has come.. It's a tricky one cuz it doesn't happen constantly.. it comes and goes... you can't hear it when you're cruising.. can't hear it when you push up/down on the car itself (this would usually have cuase the noise to be reproduced with my previous squeaking problems)... So I can't tell a mechanic what or where to look... It usually happens when the car is moving slowly (parking lot, slowing to turn speeds)... when the suspension flexes, it squeaks... Anyways.. I think its coil bind... I was thinking of getting coil spring isolators from es.. rather than doing the cheapy coil wrap method... any thoughts?
nirvanaguy
25
Oct 26, 2017 07:26 PM
czarlun
Sep 14, 2015 08:16 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
tommycanada
Sep 5, 2015 04:59 PM
