Service Manual Question?
Old Jun 12, 2004
botlbobjr's Avatar
botlbobjr is an unknown quantity at this point
Post Service Manual Question?
Installing the rear shocks for my d2 coilovers and wondering torque for three top nuts and bottom nut as well as the bolts that hold rear camber kit together. Any other advice would be appreciated.
Thanks
Old Jun 13, 2004
botlbobjr's Avatar
Bump
Old Jun 13, 2004
botlbobjr's Avatar
Some Help Please
Old Jun 13, 2004
botlbobjr's Avatar
Is there no man? J/K Please help
Old Jun 13, 2004
VNlilMAN's Avatar
The Standard One
*shrugs* i just go by the feel of it... pretty tight though. the bottom i remember i had to put all my weight into it to get it off so thats what i did.. the rear wasnt as hard but it was still pretty hard so i did the same...
Old Jun 14, 2004
Logan3024's Avatar
botbobljr, if you need help locally PM me, also if you need an alignment let me know, 50$ for 4 wheel ajustment
Old Jun 14, 2004
robbclark1's Avatar
Retired suspension supermod.
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
when i insatlled springs on my car. i didnt bother...
__________________
Old Jun 14, 2004
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
German torque: goodentite
Old Jun 14, 2004
robbclark1's Avatar
I just did that on my friend's coilover and I snapped the bolt! hahah! Home depot, we went!
Old Jun 15, 2004
botlbobjr's Avatar
Thanks again rob sorry dont have money for manual yet so i must ask
and Dizzle i would appreciate help once i get the last pieces from UI
appreciate all the help you guys aka life savers
RIPSAW
Jun 9, 2015 08:33 PM
Tim1959
Jun 3, 2015 08:15 PM
tmort
May 11, 2015 07:13 PM
cooldan1
Apr 23, 2015 10:49 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
