Tein Basic Help..Noise constantly in rear
Hello all, my Tein Basic rear shocks constantly makes a sqeaking sound. It tends to be more towards the rear left side. Practically even on flat roads it makes that sound..it sounds like a mouse got caught somewhere and it can't get out. I didn't jack up my car and check it out yet but i am doing so tonite most likely so i'm looking for a heads up on what to look for. Also the dust boot thingy has been cut and when i kick the rear left tire it makes that sound also.
check all bolts to make sure they are tight, even ones that you didn't take out to put them in. make sure springs are seated correctly.
Try taking off your tires and check around the wheel well area.
You can also try the top of the shock in the the trunk, I had the same problem it turned out he bolts were not tight enough.
BootyDo
Jun 21, 2016 03:45 PM
mistermenphis22
Jul 13, 2015 04:43 PM
SpecialRequest
Jul 7, 2015 07:52 PM
Causemo
Jul 4, 2015 07:11 AM
