Any solution for wheel hop?
Old May 17, 2004
blouisgod's Avatar
Life Begins > 6800rpms
I have my ride lowered about 2.5 all around on B&G's on 215/45/17s and I am getting serious wheel hop driving around in my city. Wheel hop is simply when you are acclerating, and you hit a bump, the drive wheel raises and misses contact with the ground. The wheel then connects to the ground and you get a huge jolt on the driveline. Not only is it bad for components, its annoying and pretty nervracking. I was thinking maybe about an underbrace or an engine dampner or just not driving at all. I know for cars with leaf springs, they make spring reinforcers that hold the leaf spring towards the ground - but we dont have leafs (duh). Let me know if you have any ideas.
I currently have installed:
Neuspeed upper front brace
RSXS rear sway
B&G coilovers
SPC Camber F&R
Generic upper rear brace
Old May 17, 2004
sjoback's Avatar
sjoback is an unknown quantity at this point
have you looked into motor mount inserts?
Old May 17, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
have u thought about slowing down?
Old May 17, 2004
Zzyzx's Avatar
Autocross Junky
You need better damping out of your struts, the B&Gs dont have high enough Rebound Dampering. also, raising up the car (giving the suspension more travel) may help reduce some of that wheel hop. of course these are things you probably didnt want to hear.
Old May 17, 2004
sw388integra's Avatar
what about a front sway bar. thats supposed to kill alot of the hop!
Old May 17, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
I still had wheelhop with my Hayame's when the front was at stock height. Oh well, you get what you pay for. I would bet the D2s are a lil' better.
Also forgot to mention - Energy Suspension has motor mount inserts out for our rides so look into them.
Old May 17, 2004
blouisgod's Avatar
I drive a civic. I can't go much slower than that unless im driving a lancer base model or a festiva. Im talking here about simply accelerating and hiting a bump.
I thought about it and i think its just part of rolling on the suspension. Im going to look into urethane inserts i guess but i dont want the vibrations from the engine to travel to the cabin. Mounts are a double edged sword.
Old May 17, 2004
Zzyzx's Avatar
Autocross Junky
If its just from you normally driving.... well then its either 1. your spring rates are too low. 2 your unsprung weight (wheels) is too high. or 3. your dampers arnt valved high enough.
Old May 17, 2004
tfnaaf's Avatar
BLDNPSI Mod
BINGO! Zzyzx hit the nail on the head
Old May 17, 2004
tfnaaf's Avatar
BLDNPSI Mod
ohh and isnt wheel hop defined more as when accelerating from a stop and the wheels spin and hop up and down trying to get traction? More common in rear wheel drive aplications. Or atleast thats what ive always called it
Old May 17, 2004
blouisgod's Avatar
Prolly my 22 lb rollers
The potholes around here are no joke; I needed a heavy duty wheel.
Old May 17, 2004
tfnaaf's Avatar
BLDNPSI Mod
heh, your 17's weigh 22lbs????????????????? lmao, my 18's are like 15lbs? You need some rotary forged
Old May 18, 2004
blouisgod's Avatar
Ha, my rims are ancient. Im looking at getting 5zigen 01r's (17" = 9.9 lbs)
Old May 26, 2004
botlbobjr's Avatar
botlbobjr is an unknown quantity at this point
those are 14 pounds, i believe onof lightest 17" rims are made by velox or centerline
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
Mr.Beefy
Aug 12, 2015 04:39 PM
swaff39
Aug 11, 2015 07:16 AM
jnissen
Aug 9, 2015 05:34 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
