Busted Koni's
Old Apr 20, 2004
orso's Avatar
orso is an unknown quantity at this point
Busted Koni's
well i blew my front struts again. thats another 350 down the drain. is anyone else having this problem or am i just to hard on my suspension?
Old Apr 20, 2004
Zzyzx's Avatar
Autocross Junky
What broke on them, and how did it happen? Koni has a Limited Life time warrenty on their shocks.....
Old Apr 20, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
My Konis blew out the bottom bolt on one of the shocks so i got a new longer bolt because the one supplied isnt long enough go to your local hardware store and grab a bolt that is the same size as your wheel studs 12x1.25 i think. and make it the ight length with a little bit of cutting
Old Apr 20, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Better check the rating on that bolt too, to make sure you don't have some week bolt that will snap in two.
Old Apr 20, 2004
streetglower's Avatar
I have been bottoming out alot lately, but it still handles great.
Old Apr 20, 2004
Zzyzx's Avatar
Autocross Junky
If you are bottoming out then you either are too low, or have too low of a spring rate for the ride height.
Old Apr 20, 2004
bobbyd's Avatar
Or your too fat!
Old Apr 20, 2004
flotsamm's Avatar
Or you didnt cut your bumpstops...
Old Apr 20, 2004
orso's Avatar
well i think when i replaced the bum- stop, dust cover thing, i left the little plastic ring inside of the old ones. i think i just sucked them apart.
you don't cut anything on the front. only on the back bumpstops do you cut.
Old Apr 20, 2004
Zzyzx's Avatar
Autocross Junky
so it was user error not build quality then?
Old Apr 21, 2004
flotsamm's Avatar
Yeah your suppose to transfer the lil white disc over or it'll suck the strut apart or sumptin like that.
Old Apr 21, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
If this isn't the first pair you've blown all indications would be that your installation is incorrect. Quadruple check the koni instructions as well as the tech manual for where everything needs to be in the upper mount and on the strut shaft itself. Also those white discs are REQUIRED or else bottoming out WILL tear the strut apart.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
cukaracha
Aug 29, 2015 05:27 PM
