upper strut mount noise on 02 coupe
Old Mar 13, 2004
sffree's Avatar
sffree is an unknown quantity at this point
ok.. b4 you direct me to another thread... I have been noticing a slight 'joint popping' noise when I turn the wheel hard left during slow driving or during parking lot-like maneuvering...I know about the 'issue' with 7th gen upper strut mounts/bearings... I have the car lowered on Eibach pros.. with koni yellows all around.. I have a neuspeed front upper tie bar, front under X bar... Ihad the upper strut mounts replaced RECENTLY.. because the noise used to be more severe and noticeble... now it's just a really subtle popping noise that seems to only happen when I turn left towards the drivers side.... After I had the mounts/bearings replaced... the installer said that the noise is normal due to being lowered on springs... is this true?? normal?? why only when i turn left?? please help/clarify.. thanks
Old Mar 13, 2004
orso's Avatar
orso is an unknown quantity at this point
mine do that every now and then. i think it is the spring just shifting in the mount. i don't think it is anything to worry about.
reqy
Jun 1, 2015 07:05 AM
GH04si
Apr 15, 2015 08:13 PM
civicR2k1
Dec 3, 2001 05:35 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
veloce
Nov 10, 2001 01:19 PM
