Suspension Question?
Old Feb 21, 2004
pjcivic's Avatar
pjcivic is an unknown quantity at this point
I've searched! When I was installing my exhaust, I noticed a problem. My drivers side sway bar link was snapped. Last week I had it replaced. I thought everything was fine, but now I've begun to notice a metal side under the hood. I don't know how to describe it other than its like the sound you have if you have a busted spring. I checked the springs and they seem fine. The only time I hear the noise is when the suspension needs to kick in (i.e bumps, potholes, etc.) I don't notice anything on a visual inspection, but I was hoping someone might be able to stear me in the right direction. It seems to be coming from both sides of the car. I tried pushing on the bumper to see if I could notice anything or if I could isolate the sound. No luck. Seems to be coming from both sides, more so the passenger side. Please help!
Old Feb 21, 2004
HondaLuver's Avatar
Its a celebration bitches!
you ripped a suspention mount. its because you hit something really hard, which snaped your endlink and also ripped your mount. next time you have your rim off look in the front of your wheel well and you will see a ripped mount that conencts to the controling arm
Old Feb 21, 2004
pjcivic's Avatar
So what does something like that run to fix? It is pssible, because it is winter in PA and the potholes are huge. I thought of a better discription of the noise. It sounds like the the motor of one of those mini frideges wobbling around when you car it.
Tedverseti
Apr 23, 2020 01:45 PM
EdGasket
40
Nov 27, 2015 11:11 AM
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
