Question about alignment?
Old Jan 26, 2004
streetglower's Avatar
I got my 2 wheel studs replaced today, one on each side. After they were done and I left the shop I noticed that my steering wheel is not straight, It is tilted to the left. Is this ok, or do I need to get an alignment? I recently had a alignment about 2 months ago when I got my car dropped and the stering wheel was in the middle, now it isnt. the car still drives straight though.
Old Jan 26, 2004
Macfay's Avatar
Macfay is an unknown quantity at this point
I have the same problem but tilted to the right...it is better to do an alignment before putting it on the road...if not, the front tires will wear unevenly, and you may need to replace the tires earlier...I'm going to fix this tomorrow...
Old Jan 26, 2004
Someone has got to have an answer to this. Well if the steering wheel is tilted, should I get a 4 wheel alignment or front wheel alignment to help with the steering wheel tilting?
Old Jan 27, 2004
Well, I got my car aligned today and they couldnt get the fron back to factory spec. It was out about 1.5 degrees. So I ordered a goldline front camber kit from robearracing.com, only $30 shipped, compared to the brake place wanting to charge $45 per bolt.
Tedverseti
Apr 23, 2020 01:45 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bsmiley
Aug 13, 2015 10:32 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
