Suspension advice
Old Jan 25, 2004
Sarvic's Avatar
Sarvic is an unknown quantity at this point
Talking Suspension advice
I have installed on my civic the Eibach Prokit along with 17" rims/tires and was wonder what you thought the next logical aftermarket part to get would be to smooth out my ride and kill some of the bounce (if ya know what I mean). Thanks!
Old Jan 25, 2004
Roy's Avatar
Roy
Roy is an unknown quantity at this point
shocks - koni now... or tokico's later (some day), and kyb (dunno when).
Old Jan 25, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
kyb is cheap and good shocks
koni is expensive and will last a lil more the kyb
Old Jan 25, 2004
Sarvic's Avatar
what about coilovers? are they worth getting or are the koni's enough. I'm not too worried about cost. I just mainly want it done right, ya know?
Old Jan 25, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
then u should return your eibach springs and get full coilovers...tein's are popular and so is JIC magic, along with the new set that just came into demand, the Hayame, priced at around 600 shipped, that's a damn unbeatable deal, considereing the cheapest tein (type basic) costs around 900. good luck to ya!
Old Jan 25, 2004
Sarvic's Avatar
is there going to be a big difference in ride if I got let's say, the Tein coilovers vs the Eibach Prokit/Koni adjustables combo?
Old Jan 26, 2004
clownprince's Avatar
Ricerus Maximus
yeah, the springs/shocks on the full coilover sets are matched between the spring rates and the dampening. The stock struts are not made for lowering and will eventually blow. The konis are adjustable and will provide about the same ride with those springs as would the full coilover setup. The main advantage of the coilovers is the fact that ride height is adjustable, with the springs you are set at a certain height.
Old Jan 26, 2004
Sarvic's Avatar
but if you are satisfied with the current height after the Eibachs, then just getting some konis should be fine then, correct?
Old Jan 26, 2004
robbclark1's Avatar
Retired suspension supermod.
yes you should ride nicely. However, be warned that you have to modify your front struts to get them to fit properly so if you plan to go back to stock one day, don't get the koni's.
You have the prokit so it is only a 1" drop so your stock shocks aren't going to take that much stress.
Old Jan 26, 2004
Sarvic's Avatar
cool, thanks!
also, i noticed on tokico's website that they are planning on coming out with the Illumina adjustables sometime in sping 04, would it be worth just waiting for them to come out because I've heard that the tokico's are better than the konis...
Old Jan 26, 2004
Ricerus Maximus
I would say go ahead and get the konis. I've been a member of this site since summer 2001 and I can't count the number of times I've heard that the tokico's are about to come out. I'm not holding my breath, I'm holding my funds for konis.
Old Jan 27, 2004
Sarvic's Avatar
do they have full replacements konis for the front and rear of our car?
Old Jan 27, 2004
Ricerus Maximus
no, only the rears I believe. (correct me if i'm wrong)
the fronts are a drop in that replaces the front shock in the strut assembly.
Old Jan 27, 2004
robbclark1's Avatar
Fronts are inserts.
Old Jan 27, 2004
Sarvic's Avatar
hmmm, i could have sworn that Koni came out with full replacements for the fronts
Old Jan 27, 2004
marc-111's Avatar
marc-111 is an unknown quantity at this point
konis fronts are inserts my friend got one with WHITELINE SPRINGS and it looks like stock but it rides good!
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
czarlun
Sep 14, 2015 08:16 PM
