Lower control arms?
Old Jan 4, 2004
berettagtz117's Avatar
berettagtz117 is an unknown quantity at this point
Lower control arms?
Does anyone have these or heard anything about them if they help our car out or not?
I know they have them for the rsx but are they the same arm for our Civics??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451029459
Old Jan 4, 2004
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
wow.. they look really nice.. don't know if they'll do anything though.. i think SPC sells one, but it also says that they are for show..... so don't know..
Old Jan 4, 2004
civicvtec1ps's Avatar
Search and Learn
Mostly bling factor. Not worth the money. No one road races that much here to effectively make use of them.OEM ones are good enough for road racing. Even SPC site says they are for show.If you check the rule books for Honda Challenge, I believe that most classes will not allow the use of aftermarket LCA's.
Old Jan 4, 2004
Zzyzx's Avatar
Autocross Junky
for certin classes in Autocross they would be helpfull... but only in the Modified and Prepaired classes...
Lower Unsprung weight helps the suspension to do its job better....
Old Jan 4, 2004
Thanks guys for the info That saves me money and something to mark off my to do list.
Old Jan 4, 2004
TOOLOWCIVIC's Avatar
So if we were to put them on our cars would they in anyway hurt our ride quality or improve it?
Old Jan 4, 2004
Zzyzx's Avatar
Autocross Junky
Its not really something that you would be able to feel... but say if you did a lot of track days and did a before/after test you'd probably shave off a tenth or two of your lap times.... The lighter control arms just let the suspension work a little better.
Old Jan 5, 2004
Search and Learn
http://store.hybridgarage.com/store/...o=007-01-0007B
Weighing in at 1.5 lbs each, these billet 7075-T6 (significantly stronger than the 6061-T6 used for most billet products) aluminum control arms not only save weight, they also allow easy adjustment of camber with their optional adjustable polyurethane camber bushings and easy installation of sway bars! These arms come standard with non-adjustable polyurethane bushings that do not affect the track of your car!
GolNat
Jan 12, 2021 09:06 PM
Tedverseti
Apr 23, 2020 01:45 PM
muttleytm
Jul 14, 2015 05:31 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
