Rear Spring/Strut Install Question
Old Dec 27, 2003
Civicman82's Avatar
Civicman82 is an unknown quantity at this point
Well I just took off my Rear Tein and when Im putting the OEM unit back on, the suspension hangs lower than where it needs to bolt on. Both sides of the car are jacked up. How can I get the suspension to line up with the bottom bolt (the one u need to push on one side of).
Thanks
Old Dec 27, 2003
Civicman82's Avatar
bump
Old Dec 27, 2003
flotsamm's Avatar
Try using a floor jack to raise it up so you can get the bolt lined up.
Old Dec 27, 2003
Civicman82's Avatar
tried that, it was lifting the car
Old Dec 29, 2003
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Get someone to stand on the rear drum brakes as described in one of the DIY spring installs ?
Old Dec 30, 2003
VNlilMAN's Avatar
The Standard One
^^^ ya thats what i did... well actually when i was doing it i didnt even take off the wheel so i had someone push on the wheel so it was alot easier
edspyhill09
Jun 12, 2016 02:45 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
rtachs
Jul 16, 2015 05:32 PM
edgenet
Apr 28, 2015 07:49 PM
ej8
Apr 13, 2015 06:36 PM
