HELP! x3racing coilover sleeve kit...
Old Dec 21, 2003
bradaven760's Avatar
bradaven760 is an unknown quantity at this point
I recently bought a set of x3racing coilover/sleeve kit, whattever you want to call it. I took apart my suspension and came to relise that the little aluminum sleeve does not fit over the shock. The sleeve just rests on the top of the plastic casing around the shock. I consulted with a buddies dad who is a mechanic, he said he has never seen anything like what i bought before. He said that under the stress that the car will put on the sleeve, it will boggle around slip off to one side and that it would just not be kosher at all. The thing that gets me is i bought this kit because it said that it would fit my 03 civic. So now that i got it and i am not sure how to install it the correct way i am asking people who may have put this kit on their car or somthing like it for help. Am i doing somthing wrong?? Please help! Any help would be excellent. Ok please write me back. Thanks!
Old Dec 22, 2003
robbclark1's Avatar
Retired suspension supermod.
Your first problem is that you bought crappy generic coilovers. They may say they fit an 03 civic, but who knows with some of the generic companies. The second thing is that they changed the mount from 01 to 02+ so you have to be careful what to buy. I would sell those and get a good set of true coilovers or some springs with Koni's because I doubt Koni's will fit with those coilovers.
Old Dec 22, 2003
Zzyzx's Avatar
Autocross Junky
I've learned that you should never go cheep with your suspension, it is afterall the only thing keeping your *** attached to the ground.
Old Dec 23, 2003
Ye ye... I hear ya guys.. they are hella cheap and i know i shouldnt have gone the cheap route, but hey they were 45 dollars. The reason i got em was because they were cheap as hell, they would lower my car and if i get them and they work hell yeah and if they dont then o well it was 50 dollars u know. It was hit or miss and i missed. SO you guys say that i should just go for a nice set or coilovers. How much do they go for. I want to get somthing that isnt necessarily like hella good, i just want somthing that will maintain stock ride but lower my car just enough to let my 18's fill the wells! Thanks again for your help. That bit about the change from 01's to 03's mount syestem was way help ful thanks fellas! If anyone has any suggestions about some nice springs or somthing that i cant get for like 200 bills help me out, and hook up the info. Thanks again talk to yalls lata!
Old Dec 23, 2003
robbclark1's Avatar
There is not much you can get for $200. If you want adjustable ride height, get Ground Control or Skunk2 sleeved coilovers. If you don't want adjustable height than I think the Eibach pro kit might be good for you. It only lowers 1" and you probably won't have a need for a camber a kit or aftermarket shocks. Please read the FAQ in my signature before you lower. Lowering requires ALOT of things to be changed. If you want a nice full coilover kit, Tein basics (~$800) will be good for you.
Old Dec 28, 2003
slowvic's Avatar
slowvic is an unknown quantity at this point
Cut factory springs, $0.00.
Old Dec 28, 2003
dirtySAMURAI's Avatar
I log in from time to time
I'm working on my suspension Koni's with Ground control coilovers. Can I just put the Koni's with the ground controls wrapped around the koni's in after I pull off the stock ones?
Old Dec 29, 2003
what does cutting your factory springs do? i know its ghetto as **** but whos lookin u know! Is it hella shitty? Shitty ride? Screw up my struts and shocks? and where do i cut them if its not that big a deal. Drop me some feed back.. Thanks guys!
Old Dec 29, 2003
robbclark1's Avatar
yes, yes, yes, yes yes yes. Cutting most springs will affect your ride and the spring quality. You can usually only do it if you cut a "dead coil" off of a spring. A dead coil is the part of the spring that compresses so that the coils are touching. Neuspeed recommends cutting one dead coil from their springs. It can only be done on certain springs....i dont remember if they have to be linear or progressive.... We will highly suggest not doing it, but if you want go ahead.
Old Dec 30, 2003
ooooooooook thanks. I guess that answers my ? I wont do it now!
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
