how can i lower my car more
Old Dec 19, 2003
lowriding619's Avatar
lowriding619 is an unknown quantity at this point
well i had sold my original b+g coilovers only to buy the same thing again but now i want to lower it all the way before i had it only lowered 2 inches now i want to go the full 3inches but the guy that installs them said not to lower it any more bacause it will ruin my tire and rims because my offset on my rims are 2 much can't i just roll the fender lips and be ok or do i really have 2 get diffrent rims...please help im on 15 x 6.5 inch tenzo sinko's on 205/55-15 with spc cambers with b+g coilovers...please any info i greatly taken sorry don't remember spec on offset of rim... thanks agine
Old Dec 19, 2003
Mr.Modify's Avatar
well if you have a camber kit the tire wear won't be a problem for the rear but do your wheels do this ---->/ \? if you got a camber kit and Full coilvers i don't see why you can't drop it even more ? what's the offset on your rims?
Old Dec 19, 2003
the offset is 35mm and no my camber is made for a real big drop of somthing like 3inches there straight up and down like l l
Old Dec 19, 2003
Mr.Modify's Avatar
35hmmm
but...
if your camber is straight then you should be able to slam that **** even with those 15's !!! why did he say your rim offset was to much? rub against the calipers or something?
Old Dec 19, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
i duno man.. i have 18's 225/40/18's 18x7.5 with 42mm offset... ur offset is wrong... i have b&g's lowered all the way.. with a camber kit.. no problems here.
Old Dec 19, 2003
this guy up here tels me i will hit the fender if i go lower but i see people on this site with it lowered more on bigger wider rims that i got he also aligns the cars to and he says if i lower it any more he refuses to align it and what does osobosted mean by my offset is wrong soes he mean my info or what
Old Dec 19, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
no the offset is wrong for ur car.
not to mention i have my fenders cut.
Old Dec 19, 2003
Mr.Modify's Avatar
offset on our cars rims is normally i beileve between aboput 42-46mm i believe ( give or take a little) 35mm would i would assume is damm near touching the calipers (might be)
Also you will not have to roll your fenders on the types of rims and tires you have cause it won't even touch your fenders!
Members on here have 215/35/18's and there **** is tucked! HTOWNBOY had his tucked like that in the rear!
Old Dec 19, 2003
thanks you guys really helped me a lot thanks so much
osobosted thanks for the info
and mr.modify thanks you have always posted such helpful info on most all my posts i can't thank you enought got looken out
Old Dec 19, 2003
Mr.Modify's Avatar
Hey mann it's cool it's always good to ask question! glad i could help though!
Old Dec 19, 2003
VNlilMAN's Avatar
The Standard One
hmm.. ok maybe i need to explain what that guy is trying to say...
you have an offset of +35mm. this will probably make the rims stick out more than your normal +42 offset. thus it is harder for you to tuck since your rims stick out. thats what he's trying to say. right now i'm runnin a +42 offset and my rears tuck no problem without a camber kit. if i had +35 like you it probably wouldnt tuck and it would hit the fenders. thats why he's saying you can slam it because your wheels stick out too much...
but who cares what he says.. TRY IT. if it rubs then raise it untill it doesnt...
Tedverseti
Apr 23, 2020 01:45 PM
bsmiley
Apr 27, 2015 01:27 PM
EvilTwin
Nov 8, 2001 12:17 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
