Is rear elignable?
Old Nov 13, 2003
agungmeth's Avatar
agungmeth is an unknown quantity at this point
Is rear elignable?
Hello,
I have a qeustion, Is rear side alignable after installing aftermarket springs?
Old Nov 13, 2003
robbclark1's Avatar
Retired suspension supermod.
what are you talking about? It seems that you are new. First off the new civics have a different suspension than the older civics. Your camber is gonna go negative in the rear rather than the front. You can buy a camber kit which will adjust for that. SPC seems to be the brand of choice. Is that what you are talking about?
Old Nov 13, 2003
agungmeth's Avatar
I mean....after calling several auto service center....all of them doesn't accept lowered car
Old Nov 13, 2003
4bangin's Avatar
some places wont do it because they cant get a lowered car on the machine or they cant get a good alignment out of a lowered car. take it to National Tire and Battery, they align them, adjust the camber, and have all the newer machines, plus they still give u a warrenty on your alignment.
Old Nov 13, 2003
agungmeth's Avatar
Can we do alignment for the rear side since our rear stock cambers are not adjustable?
Thanks.
Old Nov 13, 2003
robbclark1's Avatar
No you need to buy a rear camber kit. The front doesn't need one but it is recommended. It is just a few bolts and cheap. The rear definitely needs one if you lower more than 1". Take it to a good alignment place with a lift and full electronic alignment machine where they put the paddles on your tires.
Old Nov 13, 2003
agungmeth's Avatar
So...with rear stock cambers...we can not do alignment for the rear side?
Old Nov 13, 2003
robbclark1's Avatar
no. the older civics wouldn't have negative camber in the rear, but the new design has massive negative camber. If you lower more than 1" you wheels will tuck in. You will need a rear camber kit. The stocks aren't adjustable.
Old Nov 13, 2003
4bangin's Avatar
you can get it aligned, but your camber will still be off and your still going to be ****ing up your tires. so in order to do it correctly, you need to get a camber kit for atleast the rear and have a good shop like NTB do a 4 wheel alignment and camber adjustment.
Old Nov 14, 2003
agungmeth's Avatar
Do they accept lowered car?
Old Nov 14, 2003
robbclark1's Avatar
Yes they should. If they don't it is because your side skirts or body kit sits too low and they don't want to break it. If they don't accept lowered cars then you don't want them to align your car anyway.
Old Nov 14, 2003
4bangin's Avatar
yes ntb was the only place my shop recommended i go to since they were the only ones around my area to accept lowered cars. others may around your area but im just telling u, i know ntb accepts lowered cars.
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
czarlun
Sep 14, 2015 08:16 PM
