Front upper strut tower torque
Old Nov 6, 2003
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
Question Front upper strut tower torque
Hi all, i've searched a bit for the correct torque settings for the nuts on the front strut towers, but i've only seen one suggestion of 43 ft/lbs. Does anyone know the specific setting... i'm puttin on a sway bar and i don't want to over tighten.
Old Nov 6, 2003
IronFist's Avatar
I thought it was 33 but I don't remember.
Old Nov 6, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
yeah i thought it was 33 too
Old Nov 6, 2003
civicvtec1ps's Avatar
Search and Learn
Suspension specs...
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
it is 33ft/ lbs
Old Nov 6, 2003
hassoomi's Avatar
hmmm, does over-torquing just a little bit matter really? (well, i'm too weak to even go much over 33 ft/lbs anyway but still). right now they're on just hand-tightened.....is that okay?
Old Nov 7, 2003
robbclark1's Avatar
Retired suspension supermod.
hand tightened as you tightened them just with your fingers or hand tightened as you used a rachet? if you used a rachet that should be fine. I never torqued mine and haven't had a problem. If you just used your hand then go check them NOW and tighten them with a rachet.
Old Nov 7, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
^^ agreed... just remember how much force you used to take it off.. thats how much force you use to put it on.... general rule of thumb...
Old Nov 8, 2003
hassoomi's Avatar
haha. nah, i didn't mean just with my fingers. yeah, i used a ratchet. thanks for the help, though
MN-02-CivicEx
Jun 25, 2015 08:32 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
GH04si
Apr 15, 2015 08:13 PM
civicR2k1
Dec 3, 2001 05:35 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
