Just installed my TypeR strut bars!!!!A+++
Old Nov 5, 2003
  #31
dj02's Avatar
Originally posted by chamberlain_069
Does anyone know if there is a 1 piece strut bar. I have heard that the bolts at the joints brake.
neuspeed's strut bar is 1 piece
Old Nov 5, 2003
  #32
IronFist's Avatar
Wow, you'd have to twist a car HARD to break a strut bar.
Neuspeed front upper one is 1 piece. I think the Cusco rear one is one piece but it's like $180.
Old Nov 6, 2003
  #33
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I see that the Type-R allows room for an injen sri, but will they fit an aem sri as well?
Old Nov 6, 2003
  #34
IronFist's Avatar
If your intake goes up before the IM, like the one shown below, it won't fit.
Only Neuspeed and DC Sports fit with ones like that. So if the AEM SRI is like that, it won't fit with the Type-R bar.
Old Nov 7, 2003
  #35
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Got mine from Chinatown L.A. for $20 no tax out the door. Best $20 I've ever spent b/c it works surprisingly very well! I think I'm gonna go back and get the rear sometime...
Old Nov 26, 2003
  #36
sL3epy's Avatar
sL3epy is an unknown quantity at this point
how do u install those?
how do u install them?
front / rear strut bars....do u still hve to jack the car up before to unbolt those 3 screws or wut??? help i need to install mine asap
Old Nov 27, 2003
  #37
dacivic's Avatar
dacivic is an unknown quantity at this point
No just leave your car on flat surface. You need to tight them down 33ft/lb.
Old Nov 29, 2003
  #38
sL3epy's Avatar
wut do u mean by dat???
Old Dec 2, 2003
  #39
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Are those actualy Type R oem products from Honda or are they knock offs ? Because from the prices you quoted it would seem they are knock offs
Old Dec 3, 2003
  #40
Boiler_Room's Avatar
Boiler_Room is on a distinguished road
I have a Ractive Upper strut bar and no rear bar. I noticed a HUGE difference in the stiffness around turns. The best $30 investment I made for my car by far.
Old Dec 4, 2003
  #41
7thGenerasianCivic's Avatar
Originally posted by Looney_01Civic
they were $15 a piece plus shipping.. It cost me a total of like $55 for both shipped to my door. lol and some people pay more than that for just 1 bar!! lol
HAHA! bought the exact one for $15 out her door. LOL.
Oh...and they DO make a big difference. I recommend this product as well. I'm getting my Nuespeed front upper on Saturday. yay!
Old Dec 5, 2003
  #42
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Originally posted by HondaLuver
a 22 progress or 25mm mugen is lot bettter
Or, the comptech adjustable rear sway bar....
Old Dec 5, 2003
  #43
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
so any ways, what is a nice front-rear swaybar combo???
any thing that would get the car neutral and remove all that nasty understeer
Old Dec 5, 2003
  #44
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
The Progress 27mm front and 22mm rear bars together seem pretty popular here. Ask Grey he has this combo. That comptech adjustable looks beefy as hell but I think it costs around $600, that's more than both Progress bars + Grey's endlinks combined.
Old Dec 5, 2003
  #45
Zzyzx's Avatar
Autocross Junky
The problem with that is, understeer, oversteer and nuturalsteer are all transient states of handling. Meaning, If you tune a car to not understeer through the slow and medium speed corners, it will Oversteer in the fast corners. (As speeds increase a cars tendency to oversteer will increase). alternatlly if you tune the chassis to be nutural in highspeed conerns it will understeer more in the mid and low speed corners. you have to find a balance.
For the street, keeping the car safe and stable for average joe schmo driver, I reccomend the stock front anti-roll bar and the RSX's 19mm rear bar. If you want to spend the $$$$ go with a matched set of front and rear anti rollbars or some equivelant (Progress is a good example). If you autocross, Keep the stock front bar and get a larger Rear bar (22mm and larger preferably Adjustible) how large depends on what springs you have, the stiffer the springs the smaller the bar.
and educated guess as to how each setup will perform
Stock front + RSX rear bar.
the car will probably understeer in the slow corners (although MUCH less then stock), but in mid speed corners it will be close to nutrual, finally in High speed corners the car will have a slight case of oversteer.
Matched set Front and Rear (27mm F 22mm Rear)
this will probably have very simmilar handling chariteristics as with the Stock +RSX set up, with one big difference, Less body roll. Less body roll means that the tires contact patch will not distort as much so you will have a higher level of traction. So the car will still understeer a bit in the slow stuff, be pretty nutural in the mid speed stuf and over steer in the fast stuff. I think this would be good for the street as well as a decent set up for Track days, where corners are mostly mid to High speed. If you were to use a 25mm rear bar, I think that would be a better setup for track days as the car will want to oversteer more in the high speed corners (OK so long as you konw how to deal with it) and it will probably take mid speed corners better.
Stock Front + 22mm Rear.
Oversteer PIG. A good setup for autocross where most corners are SLow to Midspeed. So tuning the car to oversteer more in mid speed corners and be close to nutrual in slow speed corners is Great for Autocross. It might be a little unstabe for street use at its limits, but most if not every body Never reach a cars limits on the street. and Like I said before a little oversteer isnt a bad thing, as long as you dont do any thing stupid to make it worse. (Like hit the brakes or lift off the gas).
Thats my take on the whole Anti-roll bar set up issue. Please take note that this is just based on my understanding of a cars handling. Actual performance is influenced by what shocks and springs you are running
Old Dec 5, 2003
  #46
Crackhead79's Avatar
I got that Type R strut bar for mine and it was pissing me off. It didn't fit over my CAI from AEM. I sold it. Then I got a Ractive style one and quess what-it didn't fit! So, I looked around in the forum and found a part list put out for our cars. Now, I will finally get the right one that will fit. A tubular one from Neuspeed. I hate finding out the hard way. Oh, well. Thanks for the list Blur3737! Very helpful.
Tedverseti
Apr 23, 2020 01:45 PM
bluecoupe
Nov 28, 2001 08:21 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
andylao
Nov 4, 2001 01:19 PM
