drifting all the time?
Old Oct 24, 2003
Blur3737's Avatar
Blur3737 is an unknown quantity at this point
ok so far i've got my cusco rear and neuspeed front strut tie bars on and it corners a lot better, less body roll, but if i take corners too hard the whole car drifts into the other lane, my guess is cause the body wants to roll and instead of doin that the whole car rolls together and drifts, will this happen even more when i get my tanabe underbrace on? i mean i like bein able to take turns and curves faster im just worried i'll do it too hard and end up slidin off the road, maybe when i get my rims/tires they'll help me keep traction
Old Oct 24, 2003
robbclark1's Avatar
Retired suspension supermod.
sway bars will help with that. So far you are only doing chassis reinforcement. while they help with body roll, they won't work wonders. If you lower your car and change the center of gravity, they should work a little better, but sways will do more for the drifting than the strut bars.
Old Oct 24, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Welcome to the world of more neutralized handling. The problem is that the car can now take more than the tires. So if you've got stock tires, ditch them. The other thing is that you stiffened the top and left the bottoms alone. Stiffen the rear, it'll help the car rotate through corners.
Old Oct 24, 2003
Zzyzx's Avatar
Autocross Junky
um, Im thinking a severe case of understeer. are you on the gas when you take these turns? if you are you may be experianceing Power induced understeer.
But like Boilermaker said, upgrade your tires, and possibly get a larger rear anti-roll bar. and lay off the gas, dont try to accelerate untill the nose is pointed in the right direction.
Old Oct 24, 2003
dj02's Avatar
and all 3 suspension guru's speak! so yea what they said tires and a rear sway will help lots!
Old Oct 24, 2003
Jap-Euro Fusion
Well yeah... understeer is the other possibility. When he said the whole car slides... I kinda took it as sideways... which is what I can get the car to do assuming i hit the magic tire pressures.... but yeah, if its going front end first, you need a firmer *** end.
Old Oct 24, 2003
cdmx's Avatar
yep thanks to you guys, i lowered my car 1.75" got a 19mm rear sway bar + home made lower tie bar, a rear upper strut bar, a neuspeed front upper sturt bar, and a tanabe sustec underbrace.
Old Oct 25, 2003
Blur3737's Avatar
I really wanna lower my car but i'm gonna wait until i have enough money to get wheels/tires and either coilovers or springs/shocks at the same time cuz it will look bad with new wheels and not dropped, and it will also look bad dropped with stock wheels, so when i get money im gonna be doin it at the same time but i dunno when that will be
Old Oct 26, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
I tried to drift with my civic and like the guy said understeer and I crashed right into the mountain side. I was happy though, because if I were to go the other way then I would have went down a 600 foot drop. I still drift with my car but now in a parking lot or a very big road, not no narrow 2 lane road in the mountains. Reading Too much Initial D
Old Oct 26, 2003
Zzyzx's Avatar
Autocross Junky
on second thougt, you may be right boilermaker. He could just be overdriving the car. either way a good set of tires will do wonders.
Old Oct 26, 2003
Jap-Euro Fusion
It doesn't look bad as long as you pick a tire size that is nearly stock. I drove around all summer on 215/45/17s with no drop and it didn't look like a 4x4 at all. The wheel gap stays the same.
Theres nothing wrong with a drop on stock wheels either.
I don't know who engrained this "drop it or it looks bad" thing in your head (well, actually I do), but if you're making a thread about handling performance, then making excuses based on appearance, it isn't gonna work too well.
Old Oct 27, 2003
4bangin's Avatar
^^ plus dude, u live in philly, winter is a bitch on wheels, u are gunna need to switch to stock sometime through out the year. i have my stocks on now with a 1.75" drop and it looks fine in my opinion, but i do have the Si wheels.
Old Oct 27, 2003
Blur3737's Avatar
cool thanx for the input, maybe i will drop it on stock wheels and then jus save up for better rims and tires
Xuhme
21
Aug 7, 2023 03:40 PM
Tedverseti
Apr 23, 2020 01:45 PM
krazykoncepts
May 14, 2015 08:18 PM
soni
May 6, 2015 12:56 AM
GH04si
Apr 15, 2015 08:13 PM
