neuspeed front upper strut bar noise
Old Oct 21, 2003
sffree's Avatar
sffree is an unknown quantity at this point
Is it common to here a slight reverberation when reving the engine with these installed? Ever since I installed my front upper tie bar.. and when I rev the engine at low speeds.. I can here a rumbling/reverberation as the revs come down. Anyone? Anyone? As some of you may know... with the 02 and ups... you have to bend the clutch reservoir etc... to allow the bar to fit... and I'm thinking it's only vibrating against this... or maybe the bar itself is vibrating ... dunno...
Old Oct 21, 2003
robbclark1's Avatar
Retired suspension supermod.
check to make sure all the bolts are secure. If it isn't that look to see if the resevoir is rattling against it. I didn't relocate mine, just pushed it out the way.
Old Oct 21, 2003
sexcivic2k1's Avatar
not tightened all the way i bet
Old Oct 21, 2003
dj02's Avatar
never had that problem so yea check to see that its tight 75lbs of tq i belive. and it my be the cluch res u might have to push it down some more.
Old Oct 21, 2003
djmota's Avatar
75lbs are you insane??!!
do not tighten that bar up to 75lbs you will break the stud off and screw yourself.
they should be tightened to 33lbs of torque.... no more
make sure its tight and check the res for the rattling.
Old Oct 21, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
try relocating the clutch reservoir and making sure the nuts are tightened to 33lb-ft...... i think it might be the reservoir vibrating against the bar...... good luck
Old Oct 21, 2003
dj02's Avatar
i thought that was a lil tite i did my so long ago i for got how much i tq that's why i said i think
Old Oct 21, 2003
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
I just installed my neuspeed upper strut bar 2 days ago. Its 33lb/ft for the four nuts and the only other thing it could be would be the clutch fluid container. I have a 2001 so i just moved it and screwed it back in. Just check under ur hood and jiggle anything around ur strut bar to see if it moves. Thatll prob allow u to figure out whats causing the noise.
Old Oct 25, 2003
sffree's Avatar
i have an 02 coupe.. there are 2 rez's and their both labeled brake fluid(can they both be repositioned? the neuspeed install instructions only make mention to one reservoir).... both touch the bar.. from the top and bottom of the right side (driver's side) well more specifically, they rest against it--with that end of the bar going between the 2. has anyone with an 02 cpe had to deal with this? If it's not doing 'DAMAGE' to the car than i'd feel a lot better. Help...
Old Oct 28, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
i have a 02 coupe auto...and i haven't had any problems since i intsalled mine. i'd check to make sure your bolts are on tight...you can try putting a small piece of sponge or something between things to see if the rattling continues...if it doesn't...then u found your problem
Old Feb 5, 2004
SimplePinoy's Avatar
SimplePinoy is an unknown quantity at this point
I know this is an old thread but did anyone figure out that the "reverberation" noise was? i'm having the same problem but it only seems to happen when the car is cold. it goes away for the most part after it's warmed up.
Old Feb 5, 2004
robbclark1's Avatar
do you have an exhaust? If you do it might be rattling against your sway bar.
Old Feb 5, 2004
It's my front upper strut bar, not sway bar that's making a noise. it's not even close to my exhaust.
Old Feb 5, 2004
robbclark1's Avatar
it should not rattle at all. one of resevoirs might be hitting it or you didn't tighten it well enough or your over torqued it.
Old Feb 5, 2004
7gen03's Avatar
7gen03 is an unknown quantity at this point
guys mine does the same its simple the plastic cowl vibes on the bar some do some dont kinda a manufacturing thing Both the brake and clutch res are moved/cleared and it still does it its no bigge just annoying pad the back if you want theres really nothing else to make noise oh and ckeck for things touching the bar. Mines an 03 coupe
Old Feb 5, 2004
Just have a friend play with stuff while you rev the engine. You can always put a piece of cloth against whatever is rattling. Mine is on an auto, so I don't have it touching anything.
Old Feb 5, 2004
hassoomi's Avatar
so it's not just me! man, the vibrating annoyed me so much that i decided to take it off. damn $100 bucks just in the garage propped up against the wall. i think the problem is the bar touching the plastic part that 7gen03 is talking about. i thought about putting duct tape on either the bar or the plastic, but it would look pretty ghetto, so i decided not to. if anyone figures this out.......DO TELL!
edit: btw, i did everything in the install right. tightened to 33 ft-lbs and followed the instructions and all....
Old Jun 4, 2004
zen_master's Avatar
do you want to sell ur bar to me? hi hi hi
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
civicR2k1
Dec 3, 2001 05:35 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
