koni problem...help!
Old Oct 20, 2003
raconepoint7's Avatar
raconepoint7 is an unknown quantity at this point
Ive got an 01 Acura 1.7el(canada)...same as the 01 civic ex 4dr but looks alot nicer. It has macphearson strut and the problem with that is the stock shock/ strut are welded together. I got a used pair of koni yellow cartrigdes and usually, you would take out the factory cartridge and slide the new koni in its place. I was told that even if I bought the koni's brand new, I would still be in the same predicament. Im also looking into buying the 02 factory peices that I need, but Im still waiting on a price.
Ive been on many messege boards seeking some guidance...help...everyone is saying I gotta get someone to cut the factory pieces to put in the koni.
thanks
Old Oct 20, 2003
djmota's Avatar
go to the diy section and look at the intsallation of the fronts. yes. gutting the stock strut is needed to intall the koni insert. Search please, and you will find lots of information.
Old Oct 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
did you do any research before you bought these? It seems it would make sense to at least figure out what you're buying before you buy them.
You gotta cut the strut apart to install the koni.
Even if you buy new parts, you still gotta cut them up to get the konis in.
Old Oct 21, 2003
thanks....I did research it...but I was told the koni's would just slide in. The shops obviously didnt know anything about the 01 suspension. Even after I told them it was macphearson struts....oh well...I got the front koni's used @ $80 CDN...which is an offer I couldnt refuse. I got the rears in no prob.
Old Oct 21, 2003
Zzyzx's Avatar
Autocross Junky
Hey, a bit off topic but I have some cousins that live in or near Hamilton. weird.
for the shocks ya there right, you literaly have to cut the old shock out.
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
