Front strut upper tower brace question...?
Old Oct 7, 2003
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
Question Front strut upper tower brace question...?
I was just wondering, should you jack the car up, take the bolts off the towers, and put the brace on? Or can you just leave the car on the ground? Also, how do you know how tight to make the bolts once you put it on? Thanks.
Old Oct 7, 2003
civicvtec1ps's Avatar
Search and Learn
you can leave it on ground. use impact wrench . 33ft/lbs. or just tight hard (tahts what i did)
Old Oct 7, 2003
Search and Learn
Originally posted by NeonImpact
black jesus, i already told him how to do this..
find your own thread..
get outta here
Old Oct 8, 2003
Vinh's Avatar
the Neuspeed Front Upper Strut Bar didn't fit my
car at first so i jacked up the car and forced the
bar to fit and took 30 mins when suppose to take
3 mins
i'm jinx with all the bad stuff happening to me
Old Oct 8, 2003
hassoomi's Avatar
^^^ nah, i had to jack mine up, too. then i needed to take it off, so i jacked it up AGAIN (but then later i figured out that jacking it up isn't necessary when taking it off). damn thing kept on rattling at 1200 RPM.
anyway, make sure you follow the instructions; if you have the neuspeed, leave the car on the ground, put it on the passenger side screws, then if it doesn't fit on the driver side while still on the ground, you'll have to jack the car up to make it fit...
Old Oct 8, 2003
Vinh's Avatar
werd
Old Oct 9, 2003
sffree's Avatar
sffree is an unknown quantity at this point
hmm i just got the neuspeed front upper and it only has places to screw in 2 of the 3 bolts. should i be worried?
Old Oct 9, 2003
Vinh's Avatar
that's how its designed.....
i was worried when i first saw it too....
but Neuspeed is known for quality work
so don't worry about it
Old Oct 9, 2003
Majarvis's Avatar
Awesome, thanks guys!
Old Oct 9, 2003
Metallica454's Avatar
The Beer-man
Metallica454 is an unknown quantity at this point
3 mins
Actually it's supposed to be like that. It doesn't just slide on. I have the Neuspeed front strut bar. To install it, jack the car up, and unbolt all 6 nuts (3 on each side). Bolt it down loosely on the passenger side first and then it's just a matter of working the struts and the bar to get them to fit. Yes, it is supposed to be like that. Then once you get all 4 points on, torque them to 33 ft/lbs and you're goo to go!
hans.pcguy
Jul 12, 2015 12:19 PM
beachglass
Jun 1, 2015 08:28 PM
beachglass
May 22, 2015 09:59 PM
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
