Drift car?
Old Oct 7, 2003
i_SiG_Vtec's Avatar
i_SiG_Vtec is an unknown quantity at this point
Drift car?
What are the basic components to build a stable drift car for a civic coupe or other?
i.e) like a day at the track with your friends?
Old Oct 7, 2003
Zzyzx's Avatar
Autocross Junky
"Drifting" a FWD car is exceptionally tough, and the best way that I know of to get the rear end to rotate in a controlable manner, is to LEFT FOOT Brake! Learn to do that properly and you dont need a special suspension setup. but you will end up going through brakepads and Rotors pretty quickly.
RWD drift = Premature clutch wear
FWD drift = Premature Front Brake Wear.
Either way you're wearing out parts quicker then normal.
Old Oct 7, 2003
VNlilMAN's Avatar
The Standard One
dude drifting in a fwd? are you serious? is it even possible?
day at the track, eh stiffer springs being the most important one. basically lowering the car. also tires... you want to stick to the ground rather than sliding uncontrolably. sway bars. than strut/tie bars if you want
Old Oct 7, 2003
HondaLuver's Avatar
Its a celebration bitches!
with my progress rear sway bar on, i can eaisly drift my car just with a quick snappy turn of the wheel, and it also helps that my tires are crappy...
with a stiff suspention in the back and the knowhow of throwing ur back end around you can eventually learn, but don't think ur bad *** trying it on the streets cause you can eaisly loose control
Old Oct 7, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
i would use the term "slide" for fwd unless you are going reverse
Old Oct 7, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
you really can't drift FWD. Without the back wheels spinning, you slow down, as you slow down, traction is regained and the car rights itself. Its more like a controlled slide, and its not easy to do in an understeer prone car. Getting the car to slide straight sideways is an amazing feat as it is, let alone controllably oversteer it.
Stop kidding yourself.
If you wanted to drift, go buy a 240SX.
Old Oct 7, 2003
VNlilMAN's Avatar
The Standard One
ya... if you went to the drift show you'd know you wouldnt be able to do that with a fwd... its just sick
check out www.streetsportsonline.com for drift coverage from the 2 past shows
hit up the next drift showoff in irwindale, ca on oct 12(?)
Xuhme
21
Aug 7, 2023 03:40 PM
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
GH04si
Apr 15, 2015 08:13 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
