Attn PPL with lowered cars
Old Sep 25, 2003
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Ok, I my car is lowered with goldlines and when I installed my 215-45-17s today I noticed they scrape. I just want some infor from those people whos tires don't scrape. I'm going to call the company today and have them ship me either 205s or 195s, depending on what you guys have that works.
Thanx!
Old Sep 25, 2003
sexcivic2k1's Avatar
BEND THE FENDERS!
Old Sep 25, 2003
4bangin's Avatar
i have goldlines and have had both 195/50/16 and now have 205/45/17 tires and no rubbing. do u have a camber kit? is it only rubbing in the rear? if u have no camber kit in the rear and it is rubbing in the rear, that may be the reason. also, u sure u got the right offset for the wheel? that could also cause it to rub. 215/40 would be the same as my 205/45, maybe the 215/45 is a bit to thick as well. i know with the 205/45 and the drop they are close to hitting, but not hitting yet, even if i put wieght back there.
Old Sep 25, 2003
NA-01CivicSedan's Avatar
NA-01CivicSedan is an unknown quantity at this point
I have Ground Control Coilovers with 18 inch Velox rims and I have never rubbed or scraped my tires. But My drop is about 3/4 of an inch above the tire.
Old Sep 25, 2003
I have a rear camber kit. Maybe they are a little bit off, I have to have it aligned. Maybe that will make a diff. I'll do that tomorrow. It's only the Lt Rear, but I sit on the Lt so I figured it might be because of my weight. I could bend the fenders, but that's a temp. solution to a perm. problem.
Old Sep 25, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
yea, my 215s rubbed with the camber kit on. all i did was shave the fenders (rolling would probably be easier) and the problem was solved.
Old Sep 25, 2003
I guess I can roll them if the alignment doesn't fix it. Damn, tho!
Old Sep 25, 2003
blckpwdr's Avatar
blckpwdr is an unknown quantity at this point
my wheel dist. says that for 17's the right tire size to use is
205/40 17. if you go with 18's it is 215/35 18. they are the same
diameter. they won't scrape unless you go to low.
Old Sep 25, 2003
Mr.Modify's Avatar
I have 215/40/18's and i have no rub what so ever!!
Old Sep 26, 2003
Originally posted by NeonImpact
205/40/17 Kuhmo Ecsta 711 Tires
Goldline Springs (Version2 no anti-sag etc....)
No scraping or anything..
havent even rolled the fenders..
Yeah, that's the other tire I had to choose from. Mine are the 711s as well. I'll see today or tomorrow if they continue to rub.
Old Sep 26, 2003
I actually adjusted the toe-in so that it wouldn't scrape until I get to an alignment shop tomorrow.
Old Sep 27, 2003
depeche22's Avatar
depeche22 is an unknown quantity at this point
I was planning on buying 215/45/17 also, but my main concern is rubbing. It seems like there is no definitive answer whether these size tires will rub or not. I have searched and searched the forums about this topic and have resulted with mix answers. Some ppl have the same suspension setups with same size tires, but one person may rub while the other person never had any rubbing issues. I too am very interested in this issue.
I would like to know if anyone has used the Rear Performance Arm from SPC Performance? According to their site this will eliminate rubbing. I have not seen any posts indicating this as a solution so I am sceptical if these work or not. The usual answer has always been rolling the fenders, smaller tires, or raise the vehicle back up...... Well here is the link to this product, if anyone has experience with these please let everyone know if these solved the rubbing issues.
http://www.spcperformance.com/PerfPa...69100_400.html
Thanks.
Old Sep 29, 2003
ElmoZaPimp's Avatar
ElmoZaPimp is an unknown quantity at this point
2" drop with coil overs and Koni yellows front and rear
215/35/18s with 40 offset No Rubbing at all!
Old Sep 29, 2003
djmota's Avatar
Thanks.
read the description "appearance only"
Part No. 69300 - appearance only - (r, b or C)
Includes Socket - Part #69330 for installation.
Honda: 2001 & Up Civic
so they are going to be a show product and have no actual function.
on 17" rims with a big drop 215/45/17 is way too big a tire and will rub unless you have your rear camber adjusted so they tuck which will dramaticly wear out your tires quick. your choices are 215/40/17 or 205/45/17
mistermenphis22
Apr 3, 2016 08:06 AM
bsmiley
Apr 27, 2015 01:27 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
ImmortalEX
Oct 31, 2001 10:00 PM
