Camber kit Installation!!!
Old Sep 10, 2003
Mr.Modify's Avatar
DO you guys think it is a good idea to install your own rear camber kit or even the front one? i was looking at some directions and it doesn't seem that hard but it seems like you need some kinda machine to tell you how much to calibrate it? SO has anyone ever install a camber kit outta there home garage before cause i was thinking of doing it my self!!!
Old Sep 10, 2003
jedo's Avatar
jedo is an unknown quantity at this point
i did!!! i installed mine (SPC front and rear) in one day and do the alignment the same day. the install is easy, however, it is just time consuming. when ever you install it, do the alignment ASAP!!! you can feel the difference when your car is aligned properly. just a thought...
Old Sep 10, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
install it yourself, take half hr to do rear and another half hr to do front, very easy job and yes, bring it for alignment, NOTICABLE better in accleration and ride quality (for my car)
Old Sep 10, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
where did you find the directions? just wondering...
Old Sep 10, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well waht directions do you need?
unbolt the old one, bolt on the new one...
Old Sep 13, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
i thought u gotta wait a week to get an alighnment becuase u need the springs to settle?
Old Sep 13, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
To install the front:
Loosen both bolts that hold the strut to the spindle. Remove the top bolt. Install the new bolt, you will notice a cam. Install so that the cam is pointed up. This is the zero adjustment spot. Tighten the bolts.
To install the rear.
Remove the top arm. Adjust the camber kit to match the length of the stock arm. Install the new camber arm. Put a jack under the wheel hub and lift up, this will preload the spring and the bushings. Tighten everything up. This is also zero adjustment.
Take the car to an alignement as soon as possible, though you are still at the point where you are not adjusted (just like with the stock parts). So while you are not helping, you are not hurting. But your car will still be out of alignment as far as toe in/toe out. This will quickly destroy a pair of tires with too much to in or toe out.
Old Sep 13, 2003
jedo's Avatar
this is the instruction to install the rear camber....this is not for the adjustable one, but it helps....rear camber install
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
