Will I need a camber kit?
Old Sep 4, 2003
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Sup guys, I'll be buying some suspension stuff for my car (2002 LX Coupe). I'm gettin some 18's next week and need some advice on lowering kits and camber kits. I'd like to go the most I can with 18 x 7.5 rims without dealing with the rubbing what size tires do you suggest as far as protection to the rims goes? also if i put lowering springs do I need to adjust the camber? I've heard that Tein is a good brand any suggestions on that also would be greatly appreciated. Thanks.
-Matt
Old Sep 4, 2003
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/modules.p...Suspension+FAQ
Search
Old Sep 4, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
with any lowering involved a camber kit is suggested....
Old Sep 4, 2003
pheaton's Avatar
A descendant of 2k1civic.com
yeah . .get a camber kit. . do it right.
Old Sep 4, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
that's a good idea. tires are expensive, especially 18's!! no kit means wore-out tires quick!!
they will wear on the inside quick! the outside will look bran-new, inside, bald as your dad!
Old Sep 4, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Yup. . .
Search
Get camber kit
Post in correct forum.
Old Sep 4, 2003
02nithwkcivcpe's Avatar
02nithwkcivcpe is an unknown quantity at this point
u will need the camber kit and if it is possible try to find a wheel with a 7 in width. I have 7.5s and i had to roll my fenders to have my camber fixed
Old Sep 4, 2003
cdmx's Avatar
this will probably be moved to suspension
Old Sep 4, 2003
cdmx's Avatar
I wish i got a camber kit my alignment only started to get worse, and now if i slam on the brakes the car sorta swerves cause the alignment is worse on the front right tire.
Old Sep 4, 2003
JayFReaZy's Avatar
Is it true that we only need a rear camber kit for our vics? Or is it better to have both front and rear cambers? Also, I was thinking about get the eibach prokit that drops the car 1". Will it get lower than that when it "settles in"? I dont wanna lower my car too much, since at times I do have my car packed with 4 other people, plus my sub/box and 2 amps in the back. I also have 215/45/17, so im affraid I might rubb. Any suggestions?
Old Sep 4, 2003
Yukonart's Avatar
Usually the rear more than the front. . . but the front camber bolts are so cheap (comparatively) that one should just get the whole shebang.
Old Sep 5, 2003
civic4dizoor's Avatar
civic4dizoor is on a distinguished road
u dont really have to get a camber kit ... u can have ur tires flipped every 6 months or so
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
