Squeak Fix For Tein SS>>>>read!!
Old Aug 20, 2003
AirForce's Avatar
AirForce is an unknown quantity at this point
Exclamation Squeak Fix For Tein SS>>>>read!!
Alright I was messing around on here one day and I saw that people were having problems with a squeaking in the rear with their tien SS. Well I am here to save the day..lol...your problem is simple (only because i had the same problem and fixed it). What that noise you hear is your rear dust cover rubbing against the threads. So what I did is take the rear out and low and behold there were rub marks and black crap that had rubbed off onto the threads. So i pulled out my handy dany knife and cut off above the dust cover and presto no more squeakin . Hope that helps
Old Aug 20, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I had to cut mine off my B+Gs as well, so if you're having this problem with any coilover, look into this issue!
Old Aug 21, 2003
Maverick's Avatar
Maverick is an unknown quantity at this point
cool, will have to check that out
Old Aug 21, 2003
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
about how much did you cut off?
Old Aug 21, 2003
AirForce's Avatar
I just cut above where i noticed the rub marks
Old Aug 21, 2003
xHoteKx's Avatar
Tomotor
oh ok, i'll check it out tomorrow.. its too damn hot outside
Old Oct 18, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Okay, I have the squeek issue.... Started last night with my TEIN SS and I have the same problems as xHotekx has. The whole squeeking when you get in or out of the car, small bumps, or if you push the back end down. Its only on the drivers side rear though.
What exactly does the dustboot cover and are their any repercussions for this?
Old Oct 18, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Well, I sprayed some good ol' WD40 and my squeek went away, lets see how long that lasts....
Old Oct 19, 2003
DroppIN808's Avatar
DroppIN808 is an unknown quantity at this point
i had to cut my rear dust boots a lot because i had irritating squeaking sounds when i hit big bumps. But now it's good, no noise at all. When you take apart your shocks look at the dust boot and see how much is touching the coil sleeve thing. Then just cut so it wont rub on the sleeve das whats making the noise is when it rubs together.
Old Oct 19, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Yes, but the dustboot covers it for a reason, wouldnt it be bad to then cut it off and leave the stuff its covering out in the open??
Old Oct 22, 2003
Alex1's Avatar
i dont have the squeaking sound but i have a cluttering or clunking sound, anyone know what the hell that is?
Old Oct 22, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Nope sorry.
Just glad WD-40 took care of my squeeking!!!
Old Oct 27, 2003
Alex1's Avatar
well, the sound went away but i dont wanna say anything because it might come back when i hit a bump. i dont wanna jinx it.
<------ crosses fingers
Old Jan 28, 2004
matmat617's Avatar
matmat617 is an unknown quantity at this point
OK what if my springs Squeek and make some kind of poping noise when i turn my wheels?
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
popping noises is caused by the springs moving inside rather than the strut assembly rotating. What setup do you have? usually cause by improper installation
Old Jan 29, 2004
matmat617's Avatar
I have the Tein SS. Im going to take it back today then, and have Auto Bacs Fix it.
P.S. to everyone out there Super Auto Bacs, in the city of Stanton SUCKS!!
Old Jan 29, 2004
matmat617's Avatar
OK i got ahold with Tein and i need to get Bearings off a 01, does anyone know where i can get some stock parts besides Honda?
ghondavic
Transmission
Apr 12, 2017 09:37 PM
cukaracha
Jun 7, 2015 03:32 PM
reqy
Jun 1, 2015 07:05 AM
elitezdc5
May 26, 2015 05:46 PM
