Question about Koni Yellows
Old Aug 14, 2003
ElmoZaPimp's Avatar
ElmoZaPimp is an unknown quantity at this point
Question Question about Koni Yellows
1st let me start by saying I've searched the web and am still a bit hazy as to how this can be done... I know about cutting the stock strut xxmm from the top and removing the inner workings after drilling and draining the oil, as along with making sure the hole is drilled in the correct location for later attaching the new strut cartridge. My question is about fitting the koni unit into the OEM strut body . I've seen several different write ups some stating it has to be pressed in others say it can be hammered in by the diy-er. I imagine it could be hammered in using like a block of wood or someting to protect the shaft. Has any diy-er done this your input would help alot. I'm considering getting them very soon, I just lowered my car 2" and the stock struts are taking a pounding. Thanks to all that reply, Jason
Old Aug 14, 2003
djmota's Avatar
using a piece of wood and a hammer to fit the inserts will work fine. Its really not as hard as it sounds.
Old Aug 15, 2003
ElmoZaPimp's Avatar
Thanks I ordered some from tire rack, hopefully $318 a pair shipped isn't to bad for the front. I should have them here and installed in about 3 or 4 days. I'll let you know how I make out. Thanks for the help.
Old Aug 15, 2003
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
Good price, we could have been in the $289 range shipped
Old Aug 15, 2003
ElmoZaPimp's Avatar
I'll keep you in mind, If I
Old Aug 15, 2003
ElmoZaPimp's Avatar
like how the fronts work, I'm going to swap out the rears also.
alinaray
18
Aug 24, 2015 01:04 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
sch2cm
Jul 21, 2015 09:58 PM
Causemo
Jul 5, 2015 06:42 AM
