blowing out struts?
Old Aug 14, 2003
BatMan's Avatar
BatMan is an unknown quantity at this point
blowing out struts?
i heard some people say.. droping your car risks u to blow out ur struts... exactly wat happens when u blow out ur struts??
also... whats good springs to get for my car to drop it without risking to blow out the struts??
Old Aug 14, 2003
HondaLuver's Avatar
Its a celebration bitches!
the risk is that you will have a really crappy ride
just get some good shocks as well
im not sure of the good combos, people will vary on what they think is the best, i suggest true coilovers, like tein flex, ss, or basic
Old Aug 15, 2003
00celicagts6spd's Avatar
well I'll say we put tech 5 springs on and left the rest stock. i don't like the handling all that much but I drive the Celi now all the time so hard to compare. But they've been on for a few thousand miles now w/noproblem cept the camber went off finally. other than that all good. It depends the most though onhow you drive & where you drive.
Old Aug 15, 2003
VNlilMAN's Avatar
The Standard One
when you blow out your struts, a seal is broken and oil leaks out. basically its like not having shocks at all. just springs. shocks are there to improve ride quality, if you have no shocks or they're blown your ride sucks
"whats good springs to get for my car to drop it without risking to blow out the struts??"
whatever spring you use you always run the risk of blowing your shocks. even with stock springs your shocks are bound to blow. my friend his a pot hole pretty hard and his shocks were blown.
basically when you get lowering springs you are putting extra stress on the shock. lower the drop the more stress you put the more chances of blowing the shock. also stiffer the spring rate the better chance of blowing out the shock
Old Aug 15, 2003
BlackSI's Avatar
BlackSI is an unknown quantity at this point
just curious, did your friend have a em2 coupe? the one that blew his shocks over a pothole?
Old Aug 15, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
Yeah their is a problem with the struts on 2001 and 2002 civics. I've already has mine changed at honda under warranty. They know about this problem so their nice about it even though I had neuspeed sport springs on.
Old Aug 15, 2003
civicvtec1ps's Avatar
Search and Learn
your dealer owns.
my dealer would give shiet if i had aftermarket springs on
SammySC
121
Apr 7, 2017 07:43 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
Joecrowe
Sep 24, 2015 09:12 AM
