Cant adjust the damn height!
Old Aug 10, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
Angry Cant adjust the damn height!
Well, a buddy of mine put on my b&g's with me and he did all the height adjusting. I saw the whole thing and saw it was not that hard. Today I tried to adjust the height and the damn things would not budge! I dont know what to do? Have you guys had this problem?
Old Aug 10, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
That sucks man....Contact Mex he knows everything about B&g's.
Old Aug 10, 2003
TOOLOWCIVIC's Avatar
Try having ur whole car jacked up on all 4 sides. It does help a lot.
Old Aug 10, 2003
Weaponx12o's Avatar
thats weird, you should'nt have a problem adjusting them. just use 2 keys at the same time to loosen them up, then use only one key to raise or lower it. make sure that the lower lock(or whatever its called) isn't too close to the top one or else you'll be turning both. you might have to put a little force behind it the 1st couple of times because it does tend to get stuck. but after you loosened it up, its fairly easy. good luck
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Jrosa
Sep 14, 2015 08:24 PM
