RSX sway bar on 02 civic coupe. Help?
Old Aug 9, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Ok, I did use the search button first. I also looked on the net at the various sway bars/tie bars, etc.
I'm confused. Some say that you MUST beef up the suspension mounting points with a re-enforcing plate, and some say that the bigger sway bar will be fine by itself.
I got an RSX 19mm swaybar. Can I just bolt it on and use a normal tie bar? Or will the bigger bar eventually rip out the 4 mounting bolts?
I don't drive crazy, but like to be able to turn on a dime.
Suggestions?
Old Aug 9, 2003
robbclark1's Avatar
Retired suspension supermod.
the 19mm will probably not hurt anything without a tie bar. Yes, you can get a generic tie bar to brace the chassis.
Old Aug 9, 2003
Weaponx12o's Avatar
the ebay tie bars work just fine
Old Aug 9, 2003
civicvtec1ps's Avatar
Search and Learn
yea just buy cheap one . dc ones are overpriced. i went with obx low tie bar. works perfectly fine.
Old Aug 9, 2003
tinman's Avatar
Ok, what I was referring to was this extra thick plate that everything bolts through. I am ordering a tie bar today.
Look here regarding the "plate" as an example.
http://www.tornactive.com/pd_neuspeed.cfm
Several others make similar plates, claiming that the frame of the car needs to be re-enforced with this plate whenever bigger sway bars are used.
Anyone had any problems without using this? I am guessing since the RSX-S does not have this to beef up IT"S frame, it must be ok. But I just want to be sure.
Old Aug 9, 2003
robbclark1's Avatar
Those plates are attached to the bar. Progress, neuspeed and ST all have integrated tie bars, which are those plates. Tie bars do the same thing as those plates. They are just integrated with the bar. The ones with integrated ties are usually larger than 20mm.
Old Aug 9, 2003
tinman's Avatar
Aahaaa.... Ok, I got it.
Thanks.
Old Aug 9, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
The theory is tiebars only work for bars 21mm+ on older Hondas but the design in our subframe has improved compared to the older generations. There's a chance we might not need a tie bar, unless someone actually has ripped the bar off their subframe with a 22mm bar.
Anyone want to say it's happened before?
Old Aug 9, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
yes i heard an rsx broke the endlinks with a 22mm sway bar while autocrossing
Old Aug 10, 2003
robbclark1's Avatar
An endlink has nothing to do with the chassis.
Old Aug 10, 2003
its still a concern with upgrading the anti-sway bar though
Old Aug 10, 2003
All Eyes On Z
That doesn't count. Better endlinks would solve that.
Out of curiosity, I guess I should've asked but did that car NOT have a tie bar?
Old Aug 10, 2003
Grey's Avatar
DIY King
Yes it is, and for that concern there's my product: Custom End Links *Updated Again*
Poopies
Apr 20, 2017 11:36 PM
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
coupeciv
Exterior
Apr 23, 2015 06:48 AM
tattedlariat
Apr 17, 2015 03:26 AM
