front upper sway bar install
Old Aug 8, 2003
SMBFC's Avatar
SMBFC is an unknown quantity at this point
Ok I did search, couldn't find a DIY for a upper sway bar install. Very quickly and simply, How do I do it (its a DC sports Front sway bar). I hope it is as easy as NOT lifting the car, removing the nuts, put down sway bar and nuts go back down, if that is the case do they need to be torqued to a certin setting? Thanks in advance.
Old Aug 8, 2003
Zzyzx's Avatar
Autocross Junky
There is no Front upper Sway bar. its called a Strut bar or a tie bar.
a Strut bar/Tie bar is a chassis reinforcement.
A sway bar (AKA Anti-rollbar) is a suspension componant that does much the same job as your springs.
Old Aug 8, 2003
SMBFC's Avatar
correction it is a DC Sports Front Upper Strut Bar.
Old Aug 8, 2003
Zzyzx's Avatar
Autocross Junky
No worries, they are easily confused due to the similar names.
they are pretty easy to install. theres a DIY around here some where on it.
Old Aug 8, 2003
SMBFC's Avatar
Thats what im looking for, and can't find it
Old Aug 8, 2003
Weaponx12o's Avatar
it isnt hard to install. some people say to jack your car up and some people dont (i decided not to raise my car when i installed my neuspeed front strut bar), but all you have to do is:
1. take off the nuts from the struts
2. put the strut bar in place, in all 3 holes on each side
3. tighten the nuts to 33 ft. lb with a torque wrench
thats pretty much it. with the dc strut bars, you'll have to tighten the screws on it every once in a while because they tend to loosen up after a while.
Old Aug 8, 2003
SMBFC's Avatar
where did u get the 33ft lb from? just wondering b4 i do it, and how often do u do tighten in miles apx?
Old Aug 9, 2003
Weaponx12o's Avatar
i got 33 ft lbs from this site, you can also check out a helms manual. i cant tell you when to retighten them because my neuspeed strut bar doesnt require retightening. but i gues it's whenever you feel the bar is losing its effectiveness
Old Aug 9, 2003
robbclark1's Avatar
Retired suspension supermod.
Unscrew the bolts, put the bar on and torque to 33lbs. It really isn't that hard.
Old Aug 9, 2003
SMBFC's Avatar
do i need to tighten the nut pictured here or on the other side where there is a swivel? if so how tight? lb/ft?
http://www.dcsports.com/images/for%2...strutmount.jpg
Old Aug 9, 2003
robbclark1's Avatar
you need to tighten the nut on the swivel as much as possible and tighten the bolts on the shocks to 33lbs.
Old Aug 10, 2003
Marion26's Avatar
Marion26 is an unknown quantity at this point
hmmmn 33lbs how do you do that? new to diy sorry for a dumb question like that, trying to save money for installation costs so how do i do it. my neuspeed bar is coming soon need all the help i can thanks.
Old Aug 10, 2003
Weaponx12o's Avatar
you need a torque wrench. it tells you how many ft. lbs you are tightening the nut
Old Aug 10, 2003
civicvtec1ps's Avatar
Search and Learn
go buy torque wrench at sears
Old Aug 11, 2003
clownprince's Avatar
Ricerus Maximus
Or find a mechanic friend that will let you borrow his
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
jessepimpride
Nov 13, 2001 05:59 PM
PlatnumBomb
Bolt-on Engine Performance
Nov 9, 2001 01:11 PM
