Notice to all 2k2+ Tein SS owners
Old Jul 27, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
I know this has been talked about before...but here it goes
If you have a 2k2+ Civic and buy Tein SS (and probably basics as well), you have to buy the 2k1 Civic's upper bearing ring for the Tein SS to function properly.
I had the problem as I didn't put this bearing ring in the first time (as the 02 Civics dont have it), the car made noises like a popping noise in the front end when taking turns. This was because the Gold Spring Lock that Tein supplies was moving/rubbing on the upper mount which is metal. All you have to do is buy the bearing ring and put it in between the upper mount and the spring and your car is fixed.
It should cost you another $35 in parts. You do not have to buy the upper mount from the 01 Civic.
I know other people have done this and I've mentioned this as a problem before, but I'm not sure if anyone has actually posted on this site who 1. Originally Had a Problem & 2. Bought the Bearing Rings and saw the fix. If I'm wrong, this should serve as a healthy reminder.
K? Thx
Old Jul 27, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
you didn't need the upper mount bracket? I don't see how the 2k1 bearing ring could fit into a 2002+ upper mount correctly.. they design doesnt match at all. did you get pics as you fixed the problem?
edit:
see, it doesnt look like the ring could fit into the 2002+ upper mount. and if it does, it must not be sitting properly. I really really hope someone has addressed this issue to TEIN. Ground control has already released a different upper spring cup for the 2002+ civics, and since I've alerted B+G their R&D team is working on it too. they shouldn't make you pay to 'down-grade' your suspension to a 2k1
Old Jul 27, 2003
/shrug
It fit fine in mine. No, I didnt take pics.
Old Jul 28, 2003
Well not really /shrug....Tein supplies a piece (its a gold ring) with the kit that encloses the bearing with the upper mount...its actually kinda funny...it wasn't done on purpose, but it works...The piece actually has one side that looks like the 01 Upper Mount and another side that is similar to the 02 Upper Mount....Soooo you put the flat side of the bearing into the 02 upper mount, put the piece tein supplies lip first (looks like the 01 mount's lip) into the other side of the bearing, and the spring into the bottom...locking all into place.
I know that makes absolutely no sense if you haven't seen the piece I'm talking about...but if you think about it, this makes sense. I wouldn't doubt , but dont quote me on this, that the Gold Ring goes in one way in the 01, and in the 02, it goes in "upside down" compartively speaking...Would have to think about that more but I think thats right.
Old Jul 28, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
all rigt, thanks for the info. I email Tein about this 2001 and 2002 upper mounts thing.....but still no reply from them yet.
I got the basic damper, not install yet. so I'm goign to order that 2001 bearing rings. also do you know where is cheapest price on net?
thanks,
Old Jul 28, 2003
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
i never tried the 2k2 mounts on mine so i can't say wether or not they made a popping sound. i just bought the 2k1 upper mount & bearing ring when i bought my Tein's so they went right in when i did the install. but fyi they don't make any noises.
but here's a pic of the Tein Ring on the 2k1 Upper mount & bearing ring.
Old Jul 28, 2003
ya thats the gold ring im talking about
Old Jul 30, 2003
Optix's Avatar
Optix is an unknown quantity at this point
Well the 2k2 already has the bearings in the upper mount. You shouldn't need to go buy a 2k1 upper bearing
Old Jul 31, 2003
MIT's Avatar
MIT
yeh, but if you have tein ss or basic install on 02+ civic, you needed that 01 bearing, cuz that thing fit correctly on 01 civic.
Old Jul 31, 2003
gerzdavj's Avatar
gerzdavj is an unknown quantity at this point
does that go for the 03 civic ex also
Old Jul 31, 2003
Mex's Avatar
Mex
yes, the suspension changed from 2002 and on.
Old Jul 31, 2003
shelsuspensions's Avatar
shelsuspensions is an unknown quantity at this point
JUST FOR CLARITY, WHAT IS THE CORRECT PART# FOR THIS BEARING. I LOOKED AT
HONDAAUTOMOTIVEPARTS.COM:
RUBBER SEAT SPRING (UPPER)(002)-369017
SEAT FRONT SPRING (UPPER)(007)-369030
BEARING FRONT DAMPER MOUNTING (009)-369032
WHICH ONE IS IT??
THANX,
Old Jul 31, 2003
MIT's Avatar
MIT
Yes, we recently received information that there is a fitment issue with the BASIC kit for 01+ Civic on the 2002 and 2003 Civic. The simple fix would be to purchase the 2001 Civic bearing, part number 51726-S5A-004. You would need to purchase 2 of these, one for the Front Right and the other for the Front Left. Just use the 2001 Civic Bearing instead of the 02+ bearing, and install according to the instruction manual.
Please bear with us as it is difficult for us to foresee and monitor
suspension changes in vehicles in which the styling has not changed. i.e. 2001, 2002, and 2003 Civic has not changed in body style.
Email from Tein,
search below site, you will find the part u needed. i just ordered 2 bearing today from them, or you can order at any Honda dealer.
http://www.hondaautomotiveparts.com/...searchpart.jsp
Old Aug 1, 2003
jedo's Avatar
jedo is an unknown quantity at this point
are the front bearing mount the same for the SI's and the 2k2+ civic's?
Old Aug 12, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Okay- this part is on national back order. Luckily my friend at my dealer talked to corporate and is sending us one because they have the parts ready but they are lazy and have not sent them out yet.
Just to let yall know so yall dont end up having your Tein SS installed waiting on this one bearing to finish one of the struts. They will have it tomorrow morning thankfully.
Tein also doesnt suggest you drive on your Tein SS without these bearings. The shop that Im getting it installed at called them to see if I could have the car back for a day till the part comes in they high suggested that I just wait till the part comes in tomorrow.
Old Aug 12, 2003
MIT's Avatar
MIT
yeh, these 01 bearing will fix noise prob. cuz I just installed them with tein basic on 02 civic. perfeclty fine, no noise whatsoever........enjoy
cukaracha
Jun 7, 2015 03:32 PM
elitezdc5
May 26, 2015 05:46 PM
markp94
Apr 30, 2015 09:19 PM
GH04si
Apr 15, 2015 08:13 PM
