Need less body roll!
Old Jul 25, 2003
IronFist's Avatar
I think body roll is the right term. When you turn, and your car leans, that's what I'm talking about.
Ok, I want less of it
I've got Neuspeed f/u strut bar and generic r/u strut bar (they don't affect body roll, I know), and I've got an RSX-S rear sway bar. The sway bar made an awesome difference! I want more of that.
Do I need like stiffer springs or shocks or something?
Or are there any other parts that I could get that I don't know about.
Thanks.
IronFist
Old Jul 25, 2003
Jodster's Avatar
Post Whore General
Get Koni adjustable struts and some stiff springs. I like my Nuespeed race springs.
Old Jul 25, 2003
djmota's Avatar
stiffer springs would be nice but they will lower your car some. don't know if you want that or not.
if not than go with stiffer anti-sway bars
Old Jul 25, 2003
Zzyzx's Avatar
Autocross Junky
are you trying to get rid of body roll just for the sake of getting rid of body roll, or are you trying to make the car handle better?
If you want to get rid of it for no other reason then you dont like how it looks then get some stiffer anti-roll bars.
If your looking to make the car handle better, then Body roll is not the major issue you should be aiming at.
Old Jul 25, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Get some coilovers like B&G or TEIN. That'll tighten up the suspension real quick. If you're looking for a quick and low-cost solution, get the polyurethane rear sway bar bushings for the 19mm bar.
Old Jul 25, 2003
HondaLuver's Avatar
Its a celebration bitches!
get dampers, lower car and get some stiffer sway bars
Old Jul 25, 2003
IronFist's Avatar
I want it to handle better. That's why I'm trying to get rid of body roll.
So, what is the major issue I should be looking at?
Oh yeah, what are dampers? HondaLuver mentioned those.
IronFist
Old Jul 26, 2003
Zzyzx's Avatar
Autocross Junky
Body roll could be considered a sympton of a poorly handling car, not the cause of it. The real issue you need to deal with is weight transfer, or rather controling weight transfer.
Weight transfer deals Directly with how a tire makes traction. Heres a thread all about handling just so i dont have to repeat my self for the umpteenth time. If you have any questions, just post them there.
Dampiners are the corect term for shock aborbers, as contrary to their name they dont actually absorb shocks, but dampen the springs.
Old Jul 26, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Keep in mind that body roll is only what you're feeling.
But what causes body roll is simply spring compression.
Thicker anti sway/roll bars and stiffer springs is what you want but be mindful of spring rates and the thickness of your anti sway bars. Some aren't too forgiving for everyday streets with bad roads. The more you head towards performance, the more your car loses it's level of comfort.
SammySC
121
Apr 7, 2017 07:43 PM
Tedverseti
Sep 29, 2015 05:41 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
Bricoleur
Sep 9, 2015 12:30 PM
