odd noises...
Old Jul 21, 2003
gh0st's Avatar
TAQUITOS!!!!
Question odd noises...
i recently put in racer design coilovers on my civic...however i'm getting a creaking sound coming from the fron whenever i turn the wheel past a quarter turn either direction.
it's hard to describe...best word i can find to describe it is creakin...kinda like wood rubbing on each other (if that makes sense). sorry if it's so vague guys.
jus wondering if you have any ideas of what could be the cause. i could get some pics up. (where's a good place to host for free?)
thanks.
Old Jul 21, 2003
robbclark1's Avatar
Retired suspension supermod.
First off, they are racer design, not a leader in spring design. Second off, they are sleeved coilovers (i am assuming). ARe you sure you installed them correctly? Hard to diagnose a problem without seeing it.
Old Jul 21, 2003
AirForce's Avatar
AirForce is an unknown quantity at this point
If you are using the stock strut assembly here is what you do:
1. Make sure at the top of your spring make sure ALL of those tabs are tight aginst your spring and holding it.
2. Make sure every bolt is tight
the first idea comes from letting the spring kinda turn and twist because they are not held in there tight. And the second is common sense just to doulble check. CHECK ASSEMBLY
Third i have never heard of those springs; or they could be settling
Old Jul 21, 2003
gh0st's Avatar
TAQUITOS!!!!
i jus noticed the spring was turning slightly everytime i turned the wheel...so i guess it's causing the noise. =X
but last time i checked, everything was tight.
Old Jul 21, 2003
AirForce's Avatar
If your spring is turning your tabs are not tight
Old Jul 22, 2003
gh0st's Avatar
TAQUITOS!!!!
i'm still new to the modding world...
which one are the tabs
runawaykinms
15
Mar 22, 2019 10:32 AM
charmon4815
General
Sep 22, 2015 08:00 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
Mucklow
Aug 22, 2015 06:28 PM
jnissen
Aug 9, 2015 05:34 PM
