rear control arms
Old Jul 9, 2003
sihotan's Avatar
sihotan is an unknown quantity at this point
rear control arms
i have a Lx Sedan with sportlines installed. still have to get the camber kit though.
i was wondering is it normal for the rear control arms to be straight after lowering the car.
they originally looked like this /-----\ but now they are like this _------_ after lowering the car. how far do they move upward ? (when going over a bump)
does it interfere with the exhaust at all ??
Old Jul 9, 2003
Grey's Avatar
DIY King
Yes, it's normal. The lower control arms move with the suspension, so it's natural for them to move up when you lower the car. How far do they move upward? If you really want to see for yourself, then take out one of the springs and compress the suspension on that side to see the full range of motion. I think they won't bind at all; even when the shock is fully compressed.
It might interfere with certain exhausts, but it shouldn't interfere with the stock exhaust system. As long as an aftermarket system mimics the stock exhaust system placement around the lower control arm, then it should be fine. Sway bars could also interfere with the exhaust, so be careful that the combination of products you use doesn't cause any problems.
Old Jul 10, 2003
HondaLuver's Avatar
Its a celebration bitches!
its normal
Old Jul 10, 2003
prccivic's Avatar
yep..normal
Old Jul 10, 2003
sihotan's Avatar
thanks
Galvezj11
Jun 17, 2015 04:13 PM
bryden13
May 18, 2015 12:22 PM
Pudnite
May 9, 2015 07:51 PM
bluecoupe
Dec 20, 2001 07:12 PM
bluecoupe
Dec 19, 2001 07:24 AM
