spoon lower tie bar
Old Jul 7, 2003
no's Avatar
no
no is an unknown quantity at this point
spoon lower tie bar
I have two question for you all tonight
Number one is if I get the spoon lower tie bar which car should it come off to work with my civic coup the RSX or the civic SI?
Next is if I was saleing a DC sport lower tie bar would anyone buy it for $100 I have picture of it if anyone want to see.
Old Jul 8, 2003
robbclark1's Avatar
Retired suspension supermod.
There probably will be no difference from the DC sports to the spoon tie bar. Have you even upgraded your rear sway bar?? If not, then there is no need for a tie bar.
The bar should fit. I do believe it DOES NOT work with our stock bolts and you will have to drill your own into the chassis.
Old Jul 8, 2003
Grey's Avatar
DIY King
Which lower tie bar are you talking about? The one for the front or the one for the rear. I think the one for the rear is the same on the RSX and the Si, so no problem there. The one for the front is a different story. The RSX and the Si have K series engines, so it stands to reason that they have similiar front engine mount thingies (forget the name). I think the Civic's engine cradle (is that the name?) has different mounting points up front for something like a tie bar. Then again, the Neuspeed cross bar fits for the Civic and the RSX (not sure about Si). Anyway, yeah... If the cross bar from Neuspeed fits (and it does), then the Spoon Sports front tie bar will fit as well.
There, problem solved. Al of the bars will fit. IMO
Old Jul 8, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I have the DC5 Spoon bar on my car.
Old Jul 8, 2003
Green Civic's Avatar
Nice pic. About how much did you pay for that? Any hard parts in the install? Thanx.
Old Jul 10, 2003
no's Avatar
no
Yes robbclark1, I have upgrade my sway bar to the progress 22mm rear sway bar.
That why Im thinking about getting the spoon sport tie bar, because some people think
the DC sport tie bar is weack and won't protect my chassy very will and it starting to worry me. do you really have to drill holes for the rear tie bar if it for the RSX/SI??
Old Jul 10, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I still don't understand what you think is so bad about the Progress tie bar is... the whole point is that they work as a set.
Prices are gonna run $130+
The pain in the *** of the install is the lower arms move when you pull the bolts out and you need to fight them back into alignment to get the bolts back in.
Old Jul 10, 2003
no's Avatar
no
will the only problem I have with it is that when I try putting the progress tie bar on it didn't fit. Do you really have to drill holes for the spoon lower tie bar from the RSX/SI?????????
Old Jul 11, 2003
no's Avatar
no
please respond as soon as you can I want to order it as soon as I can but if I have to drill holes Im not buying it
Old Jul 11, 2003
Jap-Euro Fusion
It goes onto the bolts for the suspension arms. You don't have to drill anything. Just pull the bolt out, put the end brackets on, bolt it back in, and put the bar in between. Inanimatecarbonrod did a DIY, search for it. Who told you you had to drill?
Old Jul 11, 2003
RoadRunner's Avatar
so i have a 4dr. civic, i'm gonna need to drill holes to make the spoon lower arm bars fit ?
Old Jul 11, 2003
civicvtec1ps's Avatar
Search and Learn
no drilling required
Old Jul 12, 2003
no's Avatar
no
So you don't have to drill any holes for the spoon rear lower tie bar, right? I wasn't sure if boilermaker1 was talking about the progress tie bar or spoon.
Old Jul 12, 2003
Spoon Rear Lower Tie Bar = no hole drilling required.
Spoon Front Lower Tie Bar = no hole drilling required.
Old Jul 12, 2003
RoadRunner's Avatar
awsome thats really good then .......
Old Jul 12, 2003
Jap-Euro Fusion
Ok... the 2 bolts there are the ones that hold your lower suspension arms to the car. You simply remove them, put the Spoon endlinks on, bolt it all back together and using the supplied hardware, attach the bar between the endlinks. Done, end of story.
The only Lower Rear bar you need to drill for is the Neuspeed one.
You guys probably read Grey's DIY and he had to drill because he's got an 01 LX that did not have a sway bar from the factory.
Old Jul 13, 2003
Ya know what? I remember I made a DIY post for this thing!
http://www.7thgencivic.com/forums/sh...threadid=88801
Old Jul 13, 2003
RoadRunner's Avatar
ok thats good, no drilling makes me happy
Dave Brabant
20
Oct 6, 2015 12:44 AM
Sep 27, 2015 11:33 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
beantech
Sep 6, 2015 01:46 AM
Viczhou
Sep 2, 2015 07:55 PM
